Question about Dishwashers
Candy CDI1012 Integrated dishwasher. When I turn on the dishwasher and start it - for some reason it can not go the whole way through the cycle. When I open the door the - programme light is flashing and water is still in the bottom of the dishwasher - ie mid cycle. The water will only drain if I put it into another program to drain away - but as the dishwasher was mid cycle - the dishes are not clean
    President:
  • 2,712 Answers
Hello mm1973,
It could be because of bad door latch switches / blown thermal fuse / blown or oversensitive control board. In all these scenarios, a dismantling of the machine is required. If you have no prior experience, I'd recommend getting a professional to diagnose/service it.
Try these checks too:
  • Check water level when the fill cycle has completed. Should be just under the heating element. If not, you may need to replace the water inlet valve.
  • Check the water temperature. Should be 125 to 140°F.
  • Check pump re-circulation. Listen: does it sound like it’s spraying the water around with enough pressure?
  • Check the spray arm and pump cover for splits or leaks.
  • Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  • Make sure the dishes are loaded properly, or dishwasher is not overloaded.
Hope that helps!
Posted on May 11, 2008
    Genius:
  • 3,422 Answers
Please CLICK HERE this link will explain you everything to you step by step.
Goodluck..
Posted on May 10, 2008
Where do I find the heater element in a candy dishwasher meddled cdi1012/1-80 thanks
After click on the link beware to be a few minutes patient on the word ... processing before you see the hotspot with the word Get Manual
Its down the document preview to find .
This file is downloadable free of charge: Get Manual
(You are not logged in, only 2 downloads per day possible for you.)
CANDY CDI1012 Service Manual free download schematics eeprom repair info...
Mar 24, 2017 | Candy Dishwashers
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
Candy CDI4545 turn off delay start
Press the key to set the delay start time.This dishwasher can be delayed to start for 1 to 24 hours,and the display window beside the delay key can indicate the remaining time. If you want to cancel the delay start, just press the delay key to make the remaining time become 0.
Dado
May 17, 2012 | Candy CDI4545 Builtin Dishwasher
DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
May 09, 2012 | Candy Dishwashers
Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
May 08, 2012 | Candy Dishwashers
I have a candy integrated dishwashed and when I set it to do a wash all it does is rinse for hours
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .Inthis case as the machine seems to work on and on it seems that the fault relates to the controller. It seems that the controller does not progress in the cycle and so goes on .
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Aug 23, 2011 | Candy Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Washer keeps stopping mid cycle
Bad timer motor or mechanism...accordianman
Mar 21, 2008 | Dishwashers
Dishwashers Logo
970 people viewed this question
Top Dishwashers Experts
