Question about Dell XPS M1330 Notebook
Hello, I've got a Dell XPS M1330, I bought it at ebay and it got this problem, I thought it was just driver issues that it only display the native resolution wrong, it's supposed to be 1280 x 800 but it just keeps on 1024 x 768, also the right hand side of the display is all black, although it did worked before, I see the light from the ccfl bulb that it's working on that side, no screen damages whatsoever. I've reinstalled Windows 7 but nothing. I would like to say that the lcd video cable was really hot but I just replaced it and it's not hot anymore. Is there any way that a component of the LCD board got burned or something? Also, if I plug it to an external monitor it does shows up everything nice and correctly. Specs: Dell XPS M1330 Intel Core 2 Duo - 1.8GHz 250GB HDD 13.3" - LCD Display 1280 x 800 2GB DDR2 RAM If you need more info let me know, thanks! NOTE: Just found on google that someone had a similar problem but it was just his connector that got unplugged. I'll add the link here: http://en.community.dell.com/support-forums/laptop/f/3519/p/19308034/19602770.aspx
  • 4 more comments
  • Raul Godinez Sep 11, 2010
    Added info: I've just got a replacement lcd screen (same version, resolution and lcd) but it's the same with this one, i've read on some google pages that it's hardware malfunction. On my driver manager it shows on the "Monitors" 'Display Flat Panel (1024 x 768Hz). On the BIOS it says 'unknown display' or something like that. Like I said it did worked before but now it's not working again.Here's a picture I just took at it if someone didn't understand me. Thanks.
    http://www.glowfoto.com/static_image/11-...
    Thanks for the promp reply, I left this comment an hour ago. Here it is:
    I've posted a comment on my first post, it says that I've got a replacement LCD and it does the same thing, on the device manager where it says 'monitor' it says: digital flat panel (1024 x 768 60Hz) and on the resolution options that's the recommended resolution and I can't change it to 1280 x 800. I've attached a picture on my comment, thanks
  • Raul Godinez Sep 12, 2010
    Added info: I've just got a replacement lcd screen (same version, resolution and lcd) but it's the same with this one, i've read on some google pages that it's hardware malfunction. On my driver manager it shows on the "Monitors" 'Display Flat Panel (1024 x 768Hz). There's only one option on the refresh rate which is 60hz. On the BIOS it says 'unknown display' or something like that. Like I said it did worked before but now it's not working again.Here's a picture I just took at it if someone didn't understand me. Thanks.http://www.glowfoto.com/static_image/11-...
  • Dell Master
  • 4,737 Answers
I don't think this is a driver issue, I have had this similar problem with one of my laptop (Imperial StyleNote Laptop, only half screen is viewable), I tried everything, but at last I found out that I couldn't change the Hertz, it stuck to 60hz. I tried my best to repair it but to no avail, at last sent it to a service center and they told me that it's the Display Module issue, but unfortunately it couldn't be repaired, and the strange thing is that I can't use it and see everything on the External Monitor without any problem, but the resolution is not so good since I couldn't change it. In my case, the Display Module (IC that controls the display) could not be found to replace, so I gave up and had been using for another few months with an external monitor. At last, it's gone.
But since your's a Dell, I hope dell can fix it for you, replacing the module.
Please don't consider this as a solution, I am only telling you the cause and the only possible solution.
Good luck.
Thanks for using FixYa.
Posted on Sep 12, 2010
    President:
  • 1,851 Answers
Well your problem is not the resolution, it's the refresh rate. Go at the panel for changing the resolution and locate the "Advanced settings" button. Click on and choose the tab "monitor". At this tab change the refresh rate at a setting near to 50 - 60 Hertz and hit apply and ok. Close all the windows. Since everything is fine now you can try to increase the screen's resolution at the relative value. Mention that in case that the monitor comes to black DON'T DO ANYTHING. After 15 seconds will come back to the previous settings.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 11, 2010
    President:
  • 2,047 Answers
The problem with your unit is the screen. had a similar problem and it was because the screen got hit by something this causes the screen to display wrongly. If you have replaced the lcd cables and it is still displaying the black part you have to replace the screen. The resolution is caused by a program which runs on your device and is not compatible with the original resolution therefore the adjustment in resolution.
Hope this solution has been helpful?
  • Dell Master
  • 1,183 Answers
if the external display is working fine and you have already replaced the LCD cable.90% chances are the LCD needs a replacement. Damage on the motherboard is not that likely. You can call Dell technical support.They now can repair LCDs, which they use to repair earlier.
Dell's out of warranty repair department 1-800-288-4410
Thanks for using Fixya
Proton
Dell xps m1330 vista home curser jumps when typing
Have you loaded your touchpad drivers? The only time I've ever seen than happen is when the touchpad drivers aren't loaded. The touch is extra sensitive if your palm(s) just barely touch the pad.
By loading the touchpad drivers, you should be all set
Oct 27, 2012 | Dell XPS M1330 Notebook
The sreen of my DELL XPS M1330 suddenly does not lght up!
It can be either the display is dead or it is a loose connection. If you are still covered by warranty then I would suggest you to contact the dell technical support. They will replace the part for you.
However if you don't have a warranty then you can buy this part from dell online store (the display) and you can fix it on your own - http://ahwee.com/how-to-disassemble-laptop-dell-xps-m1330 follow the instructions here to dismantle your laptop and refix it with the new parts. If you find any troubles doing so; please let me know; I will help you further.
Best Regards NextDoorNerd
Jul 28, 2010 | Dell XPS M1330 Notebook
Dell XPS M1330 - Backlight not working
If you are having issues with a backlight I would check the lcd inverter first. It is usually 20 dollars on ebay. I would avoid contacting dell as they are no help to people that are out of warranty.
Jul 20, 2009 | Dell XPS M1330 Notebook
Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
Jun 01, 2009 | Dell XPS M1330 Laptop
Drivers for Dell XPS M 1330 for windows PX
hello piyushbansal here's a link to dells website on the pages you'll find m1330 specific drivers and patches available for download simply click on the desired file(s) and they will download to your computer where you can double click them and follow the installation instructions to get them properly installed and working on your system. plz let me know how this works out for you!
http://search.dell.com/results.aspx?spf=XPS&ssysid=XPS_M1330&ssysn=M1330&s=dhs&c=us&l=en&cs=19&ec=&ira=False&cat=sup&subcat=dyd&rf=all&evl=&nk=f&k=Dell+XPS+M1330+drivers&p=1&nf=&rpp=12&sort=K&%7Esrd=False&ipsys=False&advsrch=False&p=1
hope this helps
James
Nov 29, 2008 | Computers & Internet
Dell XPS M1330 Notebook Logo
133 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
