Question about LG Televison & Video
Lg pg42 3000 i'n Ireland using rabbits ears now that Irish channels gone digital. Perfect sound but no picture. Bit of a Luddite what am I doing wrong guys. Tx i'n advance
  • 33 Answers
This should fix your receiving problem. You should be able to use rabbit ears but they need to be out side on the roof or the very least on your porch. If this fails go out and get a powered antenna. You will have to unplug the TV for a spell this will default the computer.
Posted on Sep 03, 2010
2 tv's. recently had uverse removed. neighbor has rabbit ears-gets local channels. I get nothing. Does something with uverse change my tv's?
Your tv my have a setting for type of input. Cable of Air channels. You would need to switch that to AIr. Also, the air channels have gone to a digital signal and I believe they take "digital rabbit ears" I think the old style may not pull in the digital signal, but I'm not entirely certain about that one. Something like this http://www.amazon.com/AmazonBasics-Ultra-Thin-Performance-Indoor-Antenna/dp/B00DIFIO8E/ref=sr_1_1?ie=UTF8&qid=1409885138&sr=8-1&keywords=digital+antenna+for+hdtv+indoor
Sep 05, 2014 | Televison & Video
Add channel to TV that I deleted (using rabbit ears w/ newish digital TV)
Confirm with another set if signal for that channel is still there or not--also if not too large a set take it to someone who gets the channel and add that channel back into the memory with the remote.
Oct 30, 2012 | Samsung LN19A330J LCD TV
Can't tune 19lg3100 to Digital channels
If your using rabbit ears or outside antenna, make sure the tuner is set to AIR (via) the menu. Then Auto Program.
Feb 16, 2012 | LG Televison & Video
MY ZENITH MOD DTT901 DIGITAL CONVERTER ONLY PICKS UP TWO SPANISH STATIONS, 39-1 & 2. NO LOCAL NETS. I AM USING RABBIT EARS. WHAT'S WRONG?
Do you have digital tv that pick up local channels on rabbit ears? If you do, something in the DTT 901 menu is set wrong.
Jun 30, 2011 | Zenith Analog to Digital Audio Converter
I live in Victoria Tx. I can not afford cable or dish. I am able to recieve all 4 of the the number 25 channels. Why am I not able to recieve any of the three number 19 channes. All 19 and 25...
Channel 19 actually broadcasts on VHF channel 11 (approximately 201MHZ) and channel 25 actually broadcasts on UHF channel 15 (approximately 479MHZ). I know that sounds a bit weird but it has been done so that stations don't have to change there "call" channel number when we switched to Digital TV. Your digital converter box keeps track of this. This is important to understand because you need and antenna that is good at picking up both UHF and VHF signals. If you're not getting channel 19 it may be due to a poor VHF portion of your antenna. If your using a basic old set of rabbit ears for your antenna that has a loop in the middle then I might have a trick for you. Most rabbit ears have 2 telescopic antenna elements. Extend or collapse until each length is 14.7 inches long. (Which is a quarter wavelength at 201MHZ). You are effectively tuning (Optimizing) your antenna specifically for that channel 19. You may need to rotate your antenna a bit to find the best signal.
There are other factors which can hinder you receiving channel 19 but this is a good starting point. Let me know what type of antenna you have. Hope this helps.
Dec 03, 2010 | Insignia Digital-to-Analog Converter for...
Get no picture sound anything using rabbit ears
The FCC has changed to digital format for over the air broadcasts. You will need a digital converter box between your rabbit ears and tv now. Check radio shack or Best Buy.
Jan 31, 2010 | Craig Televison & Video
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Dec 28, 2009 | Televison & Video
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Ireland Codes for ntl/chorus mmds for digivox T
picture but no sound (irish and virgin channels only) on my digivox-t digital receiver, any solutions
Mar 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
Connecting Rabbit Ears
If you are going through a VCR, make sure you have it in Port 1, or the primary connection. Sometimes they are sticking out the front and people use the alternate port at the back for tidyness, then it won't work.
Aug 03, 2007 | LG 26LX2D 26 in. LCD HDTV
Televison & Video Logo
116 people viewed this question
Computer Repairing
Computer Repairing
