Question about Philips 43PP9202 43" Rear Projection Television
I am putting in the convergence IC's and want to replace the resistors with the proper type.I know they are 6.8 ohm 1 watt 5% but what type does it call for..metal film..carbon film..etc etc..and are their only 2 someone posted you have to replace 12???
  • guitarman45 Sep 03, 2010
    How about the type of resistors?? Metal Film? Carbon? I know the valu but do not know the type of resistor!
    I know there are between 2-12 and the type of tv and model I listed on my post..The question was what type of resistor do I replace it with? Metal film,Carbon etc etc..
  • 4 Answers
There can be between 2- 12 look near the STK chip
and see how many there are.Depends on the type and model of TV
Posted on Sep 03, 2010
I have a Hitachi 43fdx01b and I have just replaced the two convergence chips because of a "Red" convergence issue. I learned the hard way about the desoldering and resoldering, but got it done. Now i...
did you check the resistors by the convergence chips? check to see if they are open. the resistors are usually lined up on the other side of the heatsink as the convergence chips.
RK42 2.2 ohm 1 Watt
RK46 1.5 ohm 1 Watt
RK50 2.2 ohm 1 Watt
RK54 1.5 ohm 1 Watt
RK58 3.3 ohm 1 Watt
RK62 1.8 ohm 1 Watt
the convergence chips to be used are
IK04 STK394-160E Part #: CZ01341
IK05 STK394-160E Part #: CZ01341
Oct 07, 2010 | Televison & Video
Color convergence
find the change value capacitors and resistors in the convergence section!
Oct 08, 2007 | Toshiba TP50G60 50" Rear Projection...
RK46 BURNT CANNOT SEE COLORS ONLY 2 STRIPS DARK AND 2 STRIPS LIGHT. WHAT IS THE OHM VALUE AND DO I INSTAL GOLD STRIPS TOWARDS IC OR AWAY. HATACHI 43FWX20B DP24 JOE
rk46 is 1.8 ohm resistor---rk54 is the same value, rk 62 is 2.2, and Rk 42 is 3.3 ohm. It does not matter which direction it is installed---it is a resistor
If you have any questions feel free to let me know.
SD TECH
Oct 08, 2009 | Televison & Video
Magnavox 55'' Projection - Sides come in and out
sounds like Convergence issue.... I have some pictures of the bowing picture TV on the link below...
I'll post you my general message which is for a similar Philips Magnavox 51 inch TV, you'll need to check the manual verify the correct IC convergence chips and resistors, the manual link is below as well... usally the IC's are STK392-120's or 150's and the resistors are 6.8 ohm 12 of then...
anyway read the general post below it will get you headed in the right direction.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted
pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics
http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC
chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture looks like it is in 3D
Yes you need to replace both convergence ICs. They are both STK392-150 you will also need to replace the 6 feed resistors. You will need ( two ) 1.8 ohm 1watt metal film resistors.
( one) 3.3 ohm 1watt, ( 0ne) 2.7 ohm 1watt, ( one) 4.7 ohm 1 watt, and ( one ) 2.2 ohm 1watt . The resistors are all 1 watt metal film resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures, plus free tech support.
http://servicemanuals.vstore.ca/
Jul 30, 2008 | Hitachi 46F500 46" Rear Projection...
KP-57WS500
If you look at the Convergence ICs you will notice a row of resistors under the fins of the heat sink. Those are the 4.7 ohm resistors. Also in that same row of resistors you will notice the 6 yellow picos they are all lined up the picos have 4 grouped together then 1 more on each end of that row or resistors.
Jun 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Question regarding convergence resistors
yes those two resistors are also 3.9ohm 2watt 5% resistors
May 27, 2008 | Zenith R40W46 40" Rear Projection...
Excessive brightness with retrace lines
Here are the values:
RY04 >>>> 68 ohms >>>> 1 Watt
RY04A >>> 47 ohms >>>> 0.5 watt
RY02A >>> 330 Ohms >>> 0.25 Watt.
All resistors should be 5% tolerance.
Apr 17, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
