Question about Vizio L32 32 in. LCD HDTV
How do I get the picture to expand in width to fill the screen
  • 11,361 Answers
Look for 'WIDE' button on your remote, that is what on my L32 remote.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
Posted on Sep 03, 2010
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
Oct 03, 2014 | Samsung Televison & Video
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
My TV picture keeps stretching beyond the screen. Can I adjust it?
Some sets and some CABLE OR SAT BOXES also have a feature where you can adjust height or width of the picture--look carefully in both units menus to see if you have it.
Mar 30, 2012 | Televison & Video
Does not show full width of screen.
Under the settings, there's typically an option for the video width.
Under settings, go to Screen settings, then change the wide mode options to FULL.
This will make the picture fill the entire screen.
If that doesn't work, you may not be viewing an HD source. Change to an HD channel and you should have a full screen picture.
Mar 05, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Have 60 inch TV. Can not see full picture on screen. Example Nascar race could not see the scrolling bar on top. Words on bottom of screen can not see them all. Help
Make sure set is not in expanded mode. on the remote you should have a screen size button, if it is in expand or zoom it will loose part of pic. ALSO in some sets it will auto adj to expand if you have it in fill or auto mode.
Feb 21, 2011 | Sharp Televison & Video
Input from the TV or a DVD in standard width is automatically expanded to fill the wide screen. I would like to disable this feathure so that the picture is not distorted.
you need to find the picture format setting on the tv and set this to AUTO so that when the transmitted picture is 4:3 or standard it will show the 2 black/blue blocks down each side of the screen.
depending on IF your tv has this option. normally pressing menu will give you a picture option or some times there is a single button press on the remote.for example the sony tv is normally the blue "teletext" button.
Jan 17, 2011 | Televison & Video
Monitor width is out of screen
Check for shorted transistor, shorted diode, leaking/dried capacitor it could be ceramic or electrolytic. Look for some shunting diode or capacitor that is connected about horizontal size/width ciircuit. Leaking, shorted or open can make horizontal size shrink or expand.
Apr 11, 2009 | Compaq Computers & Internet
Aspect ratio
this is normal as you are looking at WIDE screen aspect ..
Mar 27, 2009 | Proscan 32LA30Q Television
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
