Question about Motorola Cell Phones
Dropped bluetooth in water how do i get to work again
Why sound volume drops low then comes back normal then drops again for a while
I'm working on a similar problem with a clarion nx604. didn't start till i did the updates necessary for the intelvoice setup and to get my bluetooth working on my phones. I will post any info i come up with.
Oct 19, 2014 | Clarion NX603 6.2 DOUBLE-DIN IN-DASH...
Hi I have a cubot p9 phone when I connect it to my car with bluetooth it works for a while I can make and receive calls but it keeps dropping out I have turned the setting on my phone to keep bluetooth on...
delete your phone from your car stereo in settings and link it up again. if that doesnt work restore your phone to factory defaults as there could be a software issue.
Jun 05, 2014 | Cell Phones
Plantronics legent got wet
only hope maybe is to find some rubbing achohol with high alcohol content and drip it in the circutry alcohol will evaporate quickly along with the water dont know if it will work if the speaker material is warped :/ i tried this method on a camera i dropped in water worked fine afterwards hope this helps you
Jan 20, 2014 | Plantronics Voyager PRO Bluetooth Headset
Water damge
if It was Dropped in that water and its not working enymore , then the components inside got Fried... if u didn't switch it on since u used it Try taking it apart to pieces and let it try and then try it again :D.
Dec 18, 2013 | Nokia Refurb BH-105 Bluetooth Headset...
Water on the bluetooth
Typically Water damage means the end of an electronic device. Leave it off for a couple of days and then try it again, but there is a good chance that it is dead.
Jun 07, 2010 | Motorola Mobility H700 Wireless Headset
Vgp-bms33 laser mouse stops working at times might start back working again later but not all the time. i checked battery level and tryed new battery's still not working. it is working fine right now so...
To conserve your batteries, most of these mouse types have a "sleep mode". If it has, you need to press the scroll wheel or a side button to wake it up after being idle for a short time. Make sure your bluetooth receiver is not obscured by anything and perhaps re-pair it again to realign the frequency.
Apr 08, 2010 | Sony VAIO VGP-BMS33/B
I dropped my player in water. will it work again.
sorry.... It might not work properly.... kindly rate me... thank you...
Jun 30, 2009 | Sony NWZ-S718FBNC 8 GB Walkman® Digital...
My Samsung D900 freezes when I activate bluetooth
Bluetooth module needs to be replaced. Bluetooth module gets to be faulty very easy, because it is on the side of the phone, so just a small drop can damage it. There is a glue around it, it this is cracked your phone is already out of warranty due to customer abuse. Other thing what can appear with your phone is short battery life.
Sep 20, 2007 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
276 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
