Question about Goodman CKL49AR49 Air Conditioner
How do I turn on the circuit breaker on my goodman ac? The smarter Tec flipped the circuit breaker. Do I turn it or push it?
  • 674 Answers
If it is the breaker box in your house, then just push it to the side so it is lined up with the other breakers in the box. Actually any breaker will be like that. If it is the disconnect outside then it pulls out and you flip it over and put it back in.
Posted on Sep 03, 2010
Breaker flips on ac
check capacitors get someone to take amp reading while running.
Aug 11, 2013 | Goodman CLQ36AR49 Air Conditioner
Unit throws off circuit breaker
THERE MAY BE A SHORT IN THE WIRING OR THE COMPRESSOR OR THE
FAN MOTOR MAY BE BAD. HAVE A AC TEC CHECK IT OUT.
Sep 01, 2011 | Goodman GPH1536M41 3 Ton 15 SEER...
I cant find the circuit breaker on my ac unit its 86 degrees in my home where is it located
Generally, the 40 amp circuit breaker can be found in your home's circuit breaker panel. In addition, there is a fuse-able cut off switch in a metal weather proof box, outside the house, adjacent to the compressor.
Hope this helps you find it. Thanks for choosing FixYa.
Aug 27, 2011 | Goodman CKL42AR42 Air Conditioner
Circuit breaker problem
if you turned the breaker to the left to turn off you must turn the breaker all the way to the right to reset it same as if you turned to the right you must turn to the left all the way to reset which ever way you turned the breaker off you need to follow thru the process in order to reset that breaker breakers are spring loaded flip it completly off than on
Apr 24, 2010 | Water Heaters
Unit will Not turn on
Hello. There is usually a separate circuit breaker in an electrical box near the outdoor component. Chances are it was turned off at that location for the winter. Joe
Apr 03, 2010 | Goodman CLQ36AR49 Air Conditioner
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Inside fan running outside not
There is an electrical box on the wall near the outdoor unit. open it and be sure that the circuit breaker is in the on position. Same in your electrical panel, be sure that the circuit breaker is turned on.
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Ehyb4 circuit breakers
First switch off the power at the main breaker or pull the meter from the meter socket. If you flip off the main breaker and it is mounted in the same breaker panel, just be aware that the wires above the breaker are still hot. Connect the white wire to the neutral bar, the green wire to the ground bar, and the black wire to the breaker. Then tilt the breaker to get the front black lug under the bar and push the back of the breaker onto the lug on the bus bar.
Feb 09, 2009 | Square D Ehb24020pl 20 A Ehb4 Ehb Circuit...
Air handler circuit breaker
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Nov 19, 2008 | Gb Electrical 1 30 Amp Ground Fault...
Goodman CKL49AR49 Air Conditioner Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
