Question about Kenwood KDC-X890 CD Player
I have an Ipod touch but I do not have the optional ipod adapter, is there any way i can still use my ipod with this system?
  • 132 Answers
Yes if you buy the IP-Bus cable and a set of RCA to 3.5mm cable. You can find at a Best Buy or online.
At best buy the IP-Bus will be 29.99 and the RCA to 3.5 is usually 10-15 bucks
Posted on Sep 03, 2010
3 Suggested Answers
  • 3422 Answers
SOURCE: Ipod touch
Do you mean that your PD100 adapter doesn't recognize your new ipod touch?
If yes then i would suggest you to only use the adapter which has been given to you with the ipod touch.Do not use anyother one.If you don't have one it is better to buy another new adapter.
Goodluck
Posted on May 10, 2008
hawk127311
  • 350 Answers
SOURCE: just purchased a 32 gig ipod touch . the unit
It appears as though you are attempting to charge the ipod with a cable that is not compatible. Some newer ipods cannot be used with older chargers and adapters for cars. Apple does this to maximize their profitability and in my opinion rip off consumers.
My daughters new ipod will work on her old FM adapter in my car but it says it does not support it on the ipod itself. It will transmit through the wire, but will not simultaneously charge it as the older ipod did both.
It is similar to cell phones and batteries. If you own the original razor and upgrade to the next generation razor, the usb connectors are different (hence the chargers will not work) and the battery connections are different so you cannot interchange batteries between the two. Even though you would think Ipods are Ipods and everything should be interchangeable, they are unfortunately not.
I hope this helps and good luck!
Posted on Feb 01, 2010
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Ipod touch
Goodluck
May 10, 2008 | JVC KD-G310 CD Player
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
Less Memory than my Ipod is Supposed to Have
You should start by restoring the iPod Nano and iPod touch using iTunes. Below is a step by step for both. This should resolve sync and capacity issues. If for some reason you have any further issues with these iPod's or this particular issue, please do let me know. I am eager to be of assistance :)
--------------------------------------------------- Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
How to restore iPod with click wheel (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apr 22, 2009 | Apple iPod touch
My ipod touch is disabled
First you need to read this page and follow the instructions on settings the touch into recovery mode
http://support.apple.com/kb/HT1808
ones in recovery mode you can remove the code by restoreing the ipod with itunes heres how
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Mar 26, 2009 | Apple iPod touch
Tip
How to install a Wi-Fi in iPod Touch
<p>The iPod Touch is a portable media player, game console and personal information manager developed by Apple. The first generation iPod Touch was released in 2007, the fourth current generation was launched in 2010 at the time of publication. Among other hardware features, the factory setting of the iPod touch already has a wireless adapter 802.11b/g/n standards for all. The operating system runs on the iPod touch is set at the factory to take full advantage of this hardware. You can sign up for free Wi-Fi with iPod touch. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." Push the "Wi-Fi" control "ON". <br /> <p><br /> <p>2. Push the "Request for new connection" control "ON". <br /> <p><br /> <p>3. Enter the radio band - usually at least 100 meters - the Wi-Fi is connecting. IPod touch displays a message asking if your network that detects the radio signal to connect. Answer "Yes". After a few seconds, you will see the Wi-Fi icon in the status bar of the iPod touch; iPod touch will be ready for the wireless network connection. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How do I Download WiFi on my iPod Touch
<p>Apple iPod touch comes with several features that distinguish it from other iPod devices, namely the touchscreen navigation interface. Another unique possibility for the iPod Touch on iPod is the device built-in wireless adapter, allowing you to make the Web browser, e-mail and web-based mobile applications. Internet access to an iPod Touch you need to download anything, but to connect the wireless adapter and search for networks. <br /> <p><br /> <p>1. Connect your iPod Touch or if it is already connected, touch iPod touch "Home" button to return to "Home" screen. Touch the "Settings", indicated by a series of gears of silver. <br /> <p><br /> <p>2. Tap "Wi-Fi." Touch the white "Off" to switch wireless adapter box. If a blue button "On", then your wireless is already enabled. <br /> <p><br /> <p>3. Scroll through the list of wireless networks that appears, and play what you want. Password input of the network, if necessary, and tap "Join". <br />
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Dec 26, 2008 | Audiovox JENSEN IPOD DIGITAL DOCKING...
Ipod Touch not charging
Scosche PassPORT USB Home Charging Adapter (Black)
Aug 16, 2008 | Homedics iSoundSpa Max Clock Radio with...
Kenwood KDC-X890 CD Player Logo
94 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
