Question about Linksys WRT54G2 Wireless Router
How to reset linksys wrt54g2? - Linksys WRT54G2 Wireless Router
    Sergeant:
  • 223 Answers
To reset these routers you will find a small (paper clip) size hole with a red button in it on the back beside the power adapter input. Press this button for at least 30 seconds while the router is on. Then unplug it. press and hold the button, then plug it back in while holding the button depressed, and keep it depressed for another 30 seconds. then power cycle it again. that should do it.
Posted on Sep 02, 2010
Pppoe password on wrt54g2
You can contact your Internet service provider for your PPPoE password.
The PPPoE password is generated and given by Internet service provider only. If you are using PPPoE connection then your Internet service provider should have password. Or they can reset and give you a new one.
Jan 01, 2012 | Linksys WRT54G2 Wireless Router
Want to modify my settings
Documentation is at
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
But this page is way more helpful
http://www.pcwintech.com/wireless-setup-linksys-wrt54g2-linksys-firmware
From a browser enter 192.168.1.1
This should give you the web interface to your router.
Your interface should look something like this:
http://ui.linksys.com/files/WRT54G2/1.5.00/
To login leave user id blank and use 'admin' as a password (default)
Note that this model has at least 3 different variants and particulars will vary:
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#WRT54G2
Jan 11, 2011 | Linksys WRT54G2 Wireless Router
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
I lost my password for my WRT54G2 Linksys router. I need it to connect my other computer to the enternet.
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1? in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
Sep 28, 2010 | Linksys WRT54G2 Wireless Router
WRT54G2 wired desktop fine, can't connect to wireless.
Hi Seth6025,
Try without using Wireless Encryption (password).
Try changing channels; default is 6; try 1 or 11.
Change your SSID: personalize it
SSID broadcast: Enable
Check the advanced wireless settings and make sure MAC filtering - DISABLED.
Reset the Linksys router by pressing RESET for 30 seconds should everything fails and re-configure. Firmware is another consideration BUT this is just a new release.
Regards,
Angel
Jul 08, 2010 | Linksys WRT54G2 Wireless Router
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
I forgot my router password and need to reset it
To reset your WRT54G2 router, locate the reset button at the left side of the rear of the router. Press and hold this button for 30 seconds. This will reset the router to factory default operation.
Apr 02, 2010 | Linksys WRT54G2 Wireless Router
I can't configure my linksys wrt54g2 v1
open a browser. type in 192.168.1.1 user name should be admin p/w admin if not, there should be a small hole in case, called reset. press this in while plugged in for 10 sec. then start again. once you are in you will find all the options. you may wish to refer to their website first.
Dec 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Oct 29, 2009 | Linksys WRT54G2 Wireless Router
Linksys WRT54G2 Wireless Router Logo
261 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
