Question about True TBB-4G Commercial Refrigerator
How do I change temperature? - True TBB-4G Commercial Refrigerator
What is a thermistor
A thermistor is a component whose
resistance changes when its temperature changes.
A thermistor is a special type of resistor whose
resistance decreases as its temperature increases.
A plot of resistance against temperature for
a thermistor is shown above. The plot is unusual
because it shows that a bigger current will flow
at a higher temperature. For most components, the
resistance increases as the temperature increases
and a smaller current flows at a higher temperature.
What is a Thermistor used for?
A thermistor can be used in a circuit to detect a
temperature change. For example, a thermistor may
be used to keep a freezer at the right temperature.
A circuit with a thermistor in it can switch the freezer on if the temperature gets too high and switch the freezer
off again when the correct low temperature is reached.
A thermistor can also be used to trigger a fire alarm. Thermistor are used in all Temperature controlled device and Motors to cut off
circuit when temperature rises over a certain limit to cut off power or trigger another circuit.
Mar 22, 2015 | Dryers
I change the temperature sensor but the needle does not move how can I change the needle? This is a 95 ford Econoline 350
you have probably been misinformed. The needle on the temperature gauge is controlled by the temperature SENDER unit ( not the temperature SENSOR unit) The sender unit is a single wire unit that is a resistance unit affected by heat of the coolant, The hotter the coolant the less resistance the higher the reading
The temperature sensor unit is a 2 wire unit that tells the ECM when to switch on the fan, when to go into limp mode if overheating and when to adjust the air/fuel mixture as the coolant warms up
Oct 20, 2014 | Ford Cars & Trucks
What is the purpose of that wire in the bottom freezer, and how does it work. not an ice maker.
If you are referring to the dual white wires with the small white plastic bulb at the end, it's the temperature thermistor. As the temperature goes up and down, the resistance in the thermistor changes as well. The electronic control sends a constant low voltage to the thermistor, and as the temperature/resistance changes, the voltage back to the board changes as well. The board interprets the voltage change, as a temperature change.
Aug 29, 2014 | Maytag MFF2558KE
Cant change the temperature
What is the complete model number of the unit?
Dec 03, 2012 | Refrigerators
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
How do I calibrate the oven temp?
Oven Temperature Adjustment Option for the MSG5770
If you think the oven should be hotter or cooler, you can adjust
it yourself. To decide how much to change the oven temperature,
set the temperature 25°F higher or lower than the temperature
in your recipe, then bake. The results of the “test” should
give you an idea of how much to adjust the temperature.
To adjust the oven temperature:
1. Press the BAKE pad.
2. Enter 550° by pressing the number pads “5, 5, 0”.
3. Press and hold the BAKE pad for several seconds until 0°
appears in the display.
4. Press any number pad to change the temperature. Each time
a pad is pressed, the temperature changes by 5°F.
• Press repeatedly to reach +35°F. Continue pressing
to reduce the temperature up to -35°F.
• If the oven temperature was previously adjusted, the
change will be displayed. For example, if the oven
temperature was reduced by 15°, the display will
show -15°.
5. When you have made the adjustment, press the
CANCEL pad and the time of day will reappear in the
display. The oven will now bake at the adjusted
temperature.
NOTE: Do not change the temperature setting more than
10° at a time before testing the oven.
It is not necessary to readjust the oven temperature if there
is a power interruption. This adjustment will not affect
broil or clean temperatures.
Feb 08, 2009 | Maytag MGS5770 Gas Kitchen Range
True TBB-4G Commercial Refrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
