Question about Xitel INport Deluxe for PC
Can't seem to install my xitell inport, can you help?
    Problem Solver:
  • 9 Answers
Xitel customers using the LP Recorder and LP Ripper software supplied with their INport are eligible for free technical support from us, CFB Software:
http://www.cfbsoftware.com/shared/support.aspx
Regards,
Chris Burrows
CFB Software
Posted on Sep 29, 2010
Which xitel product records directly from turntable
You need a turntable with a built-in phono preamplifier that has a 'Line out' output if you want to record directly from it using Xitel's INport. Alternatively you could connect your turntable to a standalone phono-preamplifier and connect the INport to its output.
Feb 26, 2014 | Xitel INport (HFLI1X1) Audio Input
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
I need a software for windows 7 for xitel inport
INport - Windows 7 compatibility
Your INport Deluxe hardware and software is all Windows 7 compatible straight out of the box. Please click below to download the Windows 7 user manual addendum for instructions on how to install your INport Deluxe hardware.
http://www.xitel.com/USA/support_inport_vista.htm
Apr 08, 2011 | Xitel INport (HFLI1X1) Audio Input
Need s registration key for xitel inport to put on my computer
I bought my'n from the home shopping channerl for $89.00
works excellent.
Feb 06, 2010 | Xitel INport (HFLI1X1) Audio Input
Need drivers for xitel inport
download this program should help ,is free ,instal it scan and update from here http://www.radarsync.com/
Nov 20, 2009 | Xitel INport (HFLI1X1) Audio Input
I lost ALL sound when Iinstalled Xitel's Inport
Have you trying to rollback using windows sistem restore
Aug 23, 2009 | Xitel INport Deluxe for PC
Lost registration code for xitel inport device
Most of the time the package of the CD the code was on it try to locate the code their else the email with do the rest.
Jul 07, 2009 | Xitel INport Deluxe
INPORT Installed, Sound Disappears
The Xitel site http://www.xitel.com/USA/support_inport.htm says when this happens, " 1. Go to START -> CONTROL PANEL -> SOUNDS AND MULTIMEDIA PROPERTIES -> AUDIO TAB
2. Make sure that in the Audio tab your soundcard appears as the Preferred Playback device with USB Audio or INport as the Preferred Recording Device. There should also be a check next to the option 'use only preferred device'.
3. When you start LPRecorder you should also make sure that Recording Device is set to USB Device or INport and Playback Device is set as your soundcard and that there is a check next to the option Simultaneous Playback."
Jul 20, 2008 | Xitel INport (HFLI1X1) Audio Input
Open Questions:
The program has worked very well for some time. Ive moved > from a windows xp computer up to a windows 7 pc. Until > recently ive had few problems trimming the track of entire > selection recording that I have made from my radio/lp/etc.., > into individual tracks/songs. Now It will only let me trim > the first half of a 3 hour 20 minute chunk of recording. > Usually almost half exactly. When i trim the recording into > individual songs, I begin by putting the end marker (red) at > the far end right side and work my way back moving the green > starter marker ever backward to pick and choose wanted > tracks to single out to keep. The recording will not play > (the cursor does not even move)until I get to the middle of > the recording itself. eventually I am only able to get half > the tracks trimmed and cant even hear the last half. Are the > settings wrong? does it have something to do with changing > from an xp to a windows 7 computer? any help is appreciated. > I cant seem to find any thing online that could explain this > or in the manual. When i moved into the new computer (xp to windows 7) i needed to get a new encoder it was "fastencc" it is now called "lame". I dont know if this is a software problem or a hardware problem. The people /makers of the product seem to be baffled at this as well. One other irritating problem that i have had is the reception from tiime to time drops in and out leaving gaps of a few seconds throughout the recording often leaving it worthless.
Feb 28, 2017 | Xitel INport Deluxe for PC
Xitel INport Deluxe  for PC Logo
189 people viewed this question
Top Xitel Computers & Internet Experts
KG John Justin
KG John Justin
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
