Question about Kenwood KDC-MP335 CD Player
I am installing this model, and a hot wire touched the case and the radio stopped working. Replaced the fuses and still nothing.it was working before this happend, what can I do to fix it?
  • 387 Answers
If the fuse blown is located outside the radio..... check the supply voltage, there is two supply voltage, the yellow wire is hot at all time and the red is through the acc. if these two wires have power, inspect some parts inside radio,
Posted on Sep 02, 2010
Is it me or does the radio panel get very hot in a ford custom van. I have a brand new ford custom and everytime I tought the radio it is scortching hot. Why is a ford custom van 2015 so hot to touch
it is all under warranty so take it back to a ford service center and have it replaced
nothing on a radio should be hot and heat indicates a shorting wire or component failure
If it that hot if is a source of fire and should be investigated or replaced
Mar 05, 2016 | Ford Cars & Trucks
PA Amplifier blows fuses
The fuse is blowing due to an overload. It's often and very likely caused by a transistor or ic that has gone short. The main culprits are the power transistors of the amp or whatever is on the big heat sink. Transistors will show the fault when you connect an ohmmeter to the terminals. It will be just like you have touched the test prods together! I don't think in your case it will be in the power supply. It's often caused by speaker cables that touch together.
Mar 18, 2014 | Radio Shack Audio Players & Recorders
My Midland just stopped working nothing works anymore
unplug the mic,take a volt meter put the setting to x1 or sound.
first thing , test the fuse to see if its burnt If its ok then check the reverse polarity diode. then if thats ok Touch the positive wire to the radio with the pos.lead then touch the pins on the mic plug.You should get some kind of tone when this is done. If you don't get a sound then go to the rear of the set and touch the neg.lead to the neg wire at the power intake and work towards the front.You should find where the tone stops soon. turn the radio over at this point and check to see if the pcb has a crack in it. There could be a bad spot on the pcb. If you find a bad spot take a piece of jumper wire from another set of course and solder across the break don't leave any wire exposed. the radio should power up
Oct 27, 2013 | Radio Communications
Cigarette lighter plug not working
hopefully nothing serious. if you can, make sure your wires did not burned or got too hot.Visually inspect them. Then, if you have a voltmeter check to see if you getiing power to it. no voltmeter? Go to your nearest auto parts store and ask for a test light. Back to the lighter, if you have power on the wires or wires leading to the back of the lighter, more than like it you lighter burned out.  No power on the wires? make sure wire did not get fryed or burned, all wires look good? check fuses again.  worst case scenario, can't find problem ? you can run another wire from your fuse box to the lighter.
May 13, 2009 | 1994 Toyota Celica
Fuse keeps blowing
This will happen when there is a hot wire touching within the wiring scheme or, it could be merging circuitry within the radios main circuit board, which is mainly heat related and will happen over a long period of usage.
I recommend running a complete wire check form the radio and o the amp and all speakers. check the main radio wire harness for worn or lose connectors. make sure the ground is secure and the hot wire isn't crossing.
In most cases, this will be caused by merging circuits within the radio itself.if this is the case, you will have to replace the radio.
Please rat and have a great weekend:)
May 09, 2009 | Car Audio & Video
Turn signals dont work 97 Geo Metro
we found the flasher curcuit had no power to the hot prong. So my friend wired the flashers hot prong into the radios fuse curcuit to get power to it and put a separate 10amp fuse on the new lead.
Jan 22, 2009 | 1991 Geo Metro
Cannot Reset 2004 Grand Cherokee Factory Radio
Double check fuses, in case one of the power wires touch something and blew a fuse. You'll have 2 power, one with & without key on.
Jan 22, 2009 | 2004 Jeep Grand Cherokee
Tripping fuses
find what fuse is, You have to follow the wires with patience, from the fuse box to the item, you have a short circuit look if the horn + wire is not touching metal outside or inside the steering column, have You replaced the steering wheel? if the same fuse covers the dome light, take it a part and see if the + wire is touching the inside of the roof, plastic melted, or look at the on and off Dome switches at both doors, look for the positive wire on radio, antenna and main light switch, yo can disconnect every item and check any time hot wiring that fuse with copper wire every time, to You are sure
Jan 21, 2009 | 1987 Chevrolet Monte Carlo
94 jeep
Sounds like you have a wire touching metal. Make sure all the Radio wires are capped or tapped.
Dec 18, 2008 | 1994 Jeep Cherokee Country
2003 Xterra radio power dead
trace the wire back to the fuse box with a lighted 12V tester and if the fuse appears to be good, check the hot side of the fuse and go from their. You might have to find another hot point (key activated) to wire the stereo into with an inline fuse.
Nov 30, 2008 | 2003 Nissan Xterra
Kenwood KDC-MP335 CD Player Logo
50 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
