Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
I have an amana washing machine -lw6501w2- when i turn on the machine and water begins to run in there is a high pitch squeeling sound as the water runs. what is the problem and is it difficult to repair. what part is required to replace?
  • 11,896 Answers
That is normally the water valves not fully opening that causes this noise. However, a faulty pump could cause this noise as well but likely you would have that noise on the drain cycle as well if the pump was bad. You can get the parts as well as see diagrams here:
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=nav8805eww&mfgModelNum=&fkMfgID=1
Posted on Sep 02, 2010
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The amana washing machine model lw6501w2 fills with water and starts agitating and spinning at the same time during the wash cycle. This causes the water to spill over the top and run out the bottom.It...
Sorry that does not sound right,,. there should be interlocks that stop agitating and spinning from happening at the same time. go to the dealer you bought it from and tell them and there may be a recall for your problem and they may replace your machine at no cost or low cost to you no matter how long you have had the machine,at least in theory..
Oct 19, 2009 | Amana Washing Machines
Wash. machine not agitating & high pitched squeel
Yep
A drive belt and when you replace it lube the gearing as well to keep them from seizing or grinding.
Jul 27, 2009 | Washing Machines
Washing maching
replace the motor coupler...you have to remove the case and then the water pump, then the motor....the coupler in behind the motor
Sep 16, 2008 | KitchenAid KAWS850L Top Load Washer
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
