Question about Coleman Powermate 27 Gallon Air Compressor
I have disassembled and cleaned the pressure switch, air valves, etc. no clogs, all in good repair. This assembly will get too hot to touch in 5-10 minutes of use. The hose will get to hot to touch in 15-20 minutes of use. The tank itself will get warm. I believe the only place that could generate this heat is the pump piston, part #048-0774. Does anyone believe replacing this part will solve the heat problem?
  • 395 Answers
The laws of physics dictate that when you compress air, it will increase in temperature, so it is quite normal for the pump and connecting pipes to get quite hot (ie: to hot to touch) reasonably quickly and associated tank and hoses to get warm also.
Make sure oil level in pump is at the correct level as it provides cooling as well as lubrication for the pump.
Posted on Sep 03, 2010
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
My dryer had no water going into the container
Not Filling With Water OTHER washers test similiarly- test water inlet valve water and pressure switch. Test the water pressure level switch a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
# Test procedures to follow
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
Jan 16, 2016 | Dryers
Service manual? 22 yrs old ...pump works but no water
How to Check a Ge/Hotpoint Washer when Is Not Filling With Water OTHER washers test similiarly- test water inlet valve water and pressure switch. Test the water pressure level switch a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
# Test procedures to follow when a GE Hotpoint washer is not filling
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
May 05, 2015 | Washing Machines
1995 sl saturn cuts out and stalls after flooring gas pedal and after restarting if I do not touch gas pedal it will limp home but if I try to accelerate it will again die
it can be a number of problems would need more info but well go with the most common need to check fuel pressure if low poss cause fuel filter clogging or fuel pump inline clogging the fuel filter is usually the problem with most stall loss of power ---if good while running check the exhaust if it feels like is choking out or low than possible cat converter clogging ---if good than check throttle body my be clogging ir need repair ---if good check egr valve my need cleaning or replacement the egr valve gets clogged with carbon also check or replace air filter these are the few most common problems that can cause a performance problem
Mar 30, 2014 | Cars & Trucks
My washer wont fill with water what seems to be the problem
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
What would cause load unload sump pressure?
Is this a rotary screw unit? Was it low unloaded sump pressure? If so the most probable cause is the minimum pressure check valve located under the aluminum cap on the seperater tank (oil tank). The check valve piston binds in the housing due to rust, dirt,etc. If you are going to attempt the repair your self I would recommend purchasing rebuild kit before disassembly.
If this problem is with a 2475 unit I would look at the pressure switch. If you are saying the unit starts/stops/starts etc and it is equiped with a low oil level switch the oil level is low. fill it to the oil fill plug threads.
Mar 03, 2011 | Ingersoll Rand Type 30 Fully Packaged Ir...
Does not stop filling up
Every washer has a water level switch. These switches work by air pressure. As water rises in the tub, air trapped in the pressure tube on bottom of the tub is squeezed till it makes a lever inside the water level switch kill the power to them water valve solenoids and shift the power over to the motor. Sand and sediment will get into the sump where that tube connects blocking the air and so the switch dont know when to shut off. Disconnect the hose at the water level switch and blow out the stuff on bottom of tub. Reconnect the tube securely and pump out any water in the tub. Restart the machine.
SOME REPAIR PIX
Dec 20, 2009 | Washing Machines
When it gets to rinse cycle it goes for a little while then shuts off with it blinking IE on the screen
Error code IE means an water inlet error. Correct water level is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. Unplug the washer before servicing.
  • Make sure the water tap is open.
  • Clean the water inlet valve filter.
  • Check the water inlet valve assembly:
  1. Remove the 2 screws on the back of the top plate.
  3. Disconnect the connectors from the inlet valve assembly one at a time and check the resistance between its terminals. Resistance should be 800-1200 ohms. Replace the inlet valve assembly if one or more of the valves is/are faulty.
  4. Check the electrical connection between the inlet valve assembly and the main board. Repair open or loose connections.89b21c3.jpg
  • If no problem or fault is found above, turn on the machine and press the SPIN SPEED and SOIL LEVEL button simultaneously to check the water level frequency. The digits on the display indicates the water level frequency. If the value is 246 or above, replace the main board.
  • If the water level frequency is below 246, check the pressure switch assembly, pressure switch tube and air chamber. The air chamber is found at the base of the washer on the other end of the pressure switch tube and connected to the bellow. Make sure they are not clogged and that the pressure switch is okay.e125ce9.jpg
Nov 25, 2009 | LG WM1812C Front Load Washer
When i clean my machine, the release valve isn't working as it should. the pressure builds up in the head and water just trickles out of the release valve. i've had my machine for approx 1 year. Could the...
There is apossible restriction, but, whatever actuates the rrelease valve is what is actually malfuctioning.Depending on you level of detertermination, you can follow my approach to the dilemna if mass production. Since it doesn't work, find out why! Worse case scenario is the trash can, the best, A better understanding and working knowledge of the appliance. Screws usually hold these things together. Expresso machines are not inexpensive and there is a reason for those big bucks. No glue! So always taking the electrical part into consideration, there is no reason you cannot disassemble the unit and entertain yourself while at the same time learn something. Always take the approach that someone assembled it and you can disassemble it. If it does have glue, rhen it was anever intended to be serviced or repaired by anyone. So give it a shot and if you run into a problem, Give me a holler and we will keep moving. My ph. # is 909-630-3192. You may have to send me a picture or two of our project, So have a camera ready.... Ned
Jun 28, 2009 | Pasquini Livia 90 Espresso Machine
Coleman Powermate 27 Gallon Air Compressor Logo
111 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
