Question about Garmin StreetPilot c340 GPS Receiver
Garmin trouble my garmin shuts off immediately after I turn it on. When first turned on the blue screen light and says Garmin but before it get to the agreement to abide by rules it cuts off.. It has been working OK.. I have searched the books , have pulled outer frame and reset, check connections to no success.its a StreetPilot c340 about one year old.
  • 3,037 Answers
Try downloading the latest firmware update off of the Garmin Website.
Let me know if you need help doing this or if this doesn't work and we can try a few other things.
thanks and good luck
I look forward to hearing back from you
Posted on May 10, 2008
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    Please don't forget to let me know your thoughts about my
    solution.
    If your problem is fixed, please rate this solution as that is one of the
    biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to
    help.
    Thank you
    Genius:
  • 3,422 Answers
Is your battery properly charged?Try replacing it with a new battery iam sure this will fix it.
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin turns on and shuts its self off.
But it might have a very low charge or a bad battery (despite being connected to Dc) recharge the battery from AC or replace the battery
Jul 24, 2009 | Garmin nuvi 255W GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
2 Garmins, BOTH shut off right after they are turned on
>>>>>Posted by judyferris82 on Mar 15, 2009 "My Garmin nuvi 650 stopped keeping a charge for more than 60 seconds. It is still connected to the car charger. Will a battery replacement fix this problem? I have had this unit for 2 years."
<<<<<REPLY: In your case, the battery seems to be getting weak. You must change it.
Mar 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Black screen displaying only Garmin and a blue triangle
to soft reset & keep data....
Slide power key to on/off, hold it for 8/10 seconds
Update from Garmin, use the web-updater. keep it updated, delete old junk and POIs.
hard reset.
Hold lower corner of screen, while turning on, keep pressing, when "clear all data appears" click yes,
sould resolve the problem
Hope this helps.
Regards.
Feb 09, 2009 | Garmin nuvi 255W GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin trouble
Battery replacement is needed!
Feb 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
