Question about Cameras
My Casio EX S600 - Upon powering up the lens opens closes beeps or buzzes 2 to 4 times and powers down ? Have made sure battery is charged after low Battery message appeared ... tried with same result
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
I have a EX-S600 Casio. When I turn it on the lens pops out, I get 3 audible beeps, hear some grinding and then the lens retracts and the camera shuts off, it all takes about about 6 to 7 seconds. I've...
If you hear a grinding then it's toast. Any issue with the mechanism would cost more to have repaired than replaced. This usually happens as a result of the lens being bumped while open or opened in a bag. Or, a contaminate such as sand inside the body of the camera.
Mar 28, 2011 | Casio Exilim EX-S600 Digital Camera
Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Casio Cameras
Lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
Mar 23, 2009 | Cameras
Nothing shows on viewing screen
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Dec 10, 2008 | Casio Exilim EX-S600 Digital Camera
I have a casio exilim ex-z60 and i accidentally drop with the lens was on, and now its stuck it wont going back(close) dis align the lens, what can i do?
try taking the battery out, and then putting it back in, and hit the power button a few times.
i drop my camera all the time.
make sure your battery is charged before you declare it broken.
[hahah, i did that once]
Nov 26, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Operation of digital camera
You all have lens errors. The only thing I can tell you is to send them into repairs.
May 31, 2008 | Casio Exilim EX-S600 Digital Camera
Casio Ex-S600 (Exilim Digital Camera)
The NP20 battery that your camera requires is not taking a charge because of a "charge error". Please contact tech support and give them your address and they will replace the battery free of cost for you.
Nov 13, 2007 | Casio Exilim EX-S600 Digital Camera
Can't make pictures-lens in not opening
I tried contacting Casio, and I was SOOOO impressed with their customer service! The camera was still under warranty - only five months old. I live outside of the US, and althought Casio would not return the camera to an address outside the US, I lucked out in having Casio return ship to someone I would see in the near future. I shipped it Fed-Ex (~ $60) at my charge; they replaced the complete lens assembly and shipped it to the US address AT NO CHARGE within 10 days!! The camera has worked perfectly ever since (4 months now).
All I can say is "Thank you, Casio! You have completely restored my faith in product warranty departments!"
Nov 03, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Lens do not open
More than likely lens is off track. send into casio to have it fixed.
Oct 19, 2007 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
