Question about Dryers
Change 3 prong dryer cord to 4 prong
What do I do with the green ground wire attached to the dryer once I attach the green wire from the power cord to the ground connection? I tried to remove the green wire attached to the dryer but it is clamped to the white middle wire. Can I connect both green wires to the ground connection?
  • 1 more comment
  • Zacattack May 13, 2008
    What is a pip? Where would an outlet box be located?
  • Lostnaltus Jul 15, 2008
    My wife is getting a new washer and dryer and donating the old set to our son for his new apartment. The problem....our house and old dryer is wired for 3 prongs. The apartment has a 4 prong outlet. That means the 20 year old dryer must be change to a 4 prong power cord and the new dryer must be adapted for our house's 3 prong outlet. How big an issue is this adaptation for both dryers? Can a novice handle the adaptation? Regards, All Thumbs
  • Anonymous Feb 20, 2009
    Same here. I don't know what to do with the existing ground wire.
I have a Maytage Gas Dryer Model SDG515DAWW that Starts up fine but once it heats up ahd the gas shuts off the first time it will not come back on. The blower keeps running but no heat
Posted on Dec 14, 2009
  • 101 Answers
Well the green wire is the earth ground,you could connect it to a pip,or to the outlet box.
Posted on May 11, 2008
  • Ping ong May 13, 2008
    connect it to the screw of the outlet box.
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Just moved into an older home with a 3 prong dryer receptacle. My whirlpool duet dryer model: GEW9250PL1 currently has a 4 prong cord. I have purchased the 3 prong cord and am ready to install. Very...
Hi, White, green green/white striped they are all the same....only thing you really have to worry about is that you have the red and black in the proper places...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 13, 2011 | Dryers
Need to change the power corrd to a 4 prong from the 3 prong but the 3 prong cable isnt color coordinated, how do I hook up the new power cord?
The new cord has a green ground wire; two hot wires, which are black and red; and a white neutral wire. Attach the neutral to the middle connector and the two hot wires to either end of the terminal.
In order to safely ground the machine the green ground wire must be securely connected to the dryer frame. There may be a screw on the frame where you can attach the ground.
Jun 24, 2011 | Kenmore 62622 Electric Dryer
I was given the dryer, and the cord unattached. I want to be sure I attach them correctly. The cord has three prongs and ther are three holes for attachment. Where should the grounding be atached?
For a 3-pronged cord, the ground (nuetral) is the middle wire on the cord and is attached to the middle terminal post. the outside wires are attached to the outside posts. It doesn't matter which wire goes to which side.
On 4-pronged cords, there is a fourth green wire that is attached the unit's case for grounding purposes. Which cord you use is dictated by what power outlet you have, 3 or 4-pronged.
If I can help anymore, please let me know.
Best, G
Aug 03, 2010 | Whirlpool Dryers
Can i change a dryer with a 3 prong cord to accomidate a 4 prong outlet..if so, how?
Yes, no problem. here are the pictures. You will need the proper cord.
The first picture is the standard 3 prong, the second is the 4 prong version.
Apr 14, 2010 | Maytag SDE3606A Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
Changing from 3 prong to 4 prong cord
Mar 19, 2009 | Dryers
Trying to change from 3 prong to 4 prong and there are 4 wires to connect to back of dryer.
511ca90.jpg It should go something like this ; depending on the brand and age. just remember, white in the middle ; this is the most important thing.
Aug 12, 2008 | Dryers
Dryers Logo
2,870 people viewed this question
Top Dryers Experts
