Question about Kenwood KDC-MP642U
I heva a kdc-mp642u and has no power on the display apears protect
  • juatemoc Sep 03, 2010
    i take out the ic and put the new one and i still have the same problem do you have another idea
  • 132 Answers
When you bought the radio there should be 2 metal hook looking things inside of the box.
Take the faceplate off the radio
Remove the black trim ring by gently prying with flathead screwdriver to remove.
Stick in the two metal bars on the left and right side and slide in until it clicks.
Pull towards you gently and the whole radio should begin to slid towards you.
You can grasp the radio and pull as soon as you have enough to grip it.
Then see if you have 12 volts when the key is turned forward on the RED and YELLOW wire either with a test light or a meter.
If you have 12 on one, but not the other then you need to refer to car owners manual for the radio fuse.
Or get back with me with the year make and model of car and I can help you with fuse finding.
Posted on Sep 07, 2010
  • Kenwood Master
  • 17,129 Answers
Possible that the outputt is short and the audio power output IC is defective . Disconnect the speakerrs to check out one again.
If fault stays then disconnecct the powerr supply to the output IC.
If the protect display changes, then the IC is short for sure.
Posted on Sep 03, 2010
  • Donald DCruz
    Donald DCruz Sep 03, 2010
    Cut the main power to the output circuits and if the short corrects, then check for short.
Subwoofer wont play
For a sub to play it needs wiring from sub to amp and the amp needs power from battery and amp needs signal from radio and amp needs to be grounded oh and it needs a remote signal from the radio as well and if your radio is stock and has no RCA outputs you need a LOC which will connect to you speakers with wire and to your amp with RCAs
Jan 05, 2014 | Kenwood KDC-MP642U
Cd in kenwood car stereo, car is dead
yes open the stereo and get the cd from inside out
Apr 15, 2013 | Kenwood KDC-MP642U
COMO QUITAR PROTECT ESTEREO KENWOOD KDC-MP642U
En estos modelos quedan grabados los errores de DC en el eeprom y se tiene que limpiar y estos son los pasos para este modelo:
Mientras que el display muestre PROTECT presiona el y sosten el 3 y 6 y luego presiona el RESET mantelos presionados por unos dos o tres segundos y luego suelta el RESET y despues de uno o dos segundos suelta los otros switches.
El display debe mostrar:
DC ERR
Presiona el 1 y el display mostrara
DC1 ERR
Presiona el 1 y sostenlo por par de segundos y el display mostrara
DC1 OK
Presiona el 2 y el display mostrara
DC2 4
Presiona el 2 y sostenlo por un par de segundos y el display mostrara
DC2 0
A este punto el eeprom ya esta limpio y nada mas presiona el RESET y el disply debe mostrar STANDBY
Espero que esta informacion te sea util y avisa si te funiona
Suerte y saludos
Jan 27, 2013 | Kenwood KDC-MP642U
How do I hook up the auxiliary cable to a G1700 JL AMP from this radio?
the signal RCA cables and the power control wire go to the head unit. the power and ground go to + and - terminals, and the speaker wire goes to the corresponding clips on the speaker driver.
May 05, 2011 | Kenwood KDC-MP642U
What wire is the REM wire on the Kenwood kdc-mp624u head unit?
The standard remote turn on wire color is blue with a white stripe.
Apr 13, 2011 | Kenwood KDC-MP642U
I've been trying to figure out how to adjust my sound because ever since I got the KDC MP642U my bass has been nearly non existant. I looked in the manual and it says to go to the sound category to adjust,...
You've probably figured this out by now, but you are supposed to go through the FNC button, click the control knob left, scroll down to SOUND, click and it will show you a menu with Control, Setup, and Preset, etc., and under the Control will list the EQ, bass boost, and highway sound. Under Setup you can adjust the frequency sensitivity under the X-Over option, the type of cabin, location of speakers for central sound, it's all there. Also, on the main display, if you hold the volume knob down for a second, you can adjust the dB level. If still nothing, check if the sub is on. On the main display, hold down on the control knob for two seconds, if will toggle the sub on or off. One thing I'm stumped by however is that I am either getting no subwoofer output, or just any amplifier output at all when trying to use the aux source and the USB source. I had gone through all these settings under each source, i still got nothing. I would assume that this can't not be an option for these sources. I need help.
May 23, 2010 | Kenwood KDC-MP642U
Have a kenwood deck, kdc mp642u, battery went dead and know we cant get it unlocked..How do we unlock it?
here is the website to get the unlock code good luck
http://mike-unlockcodes.blogspot.com
Oct 21, 2009 | Kenwood KDC-MP642U
I'm trying to install my new kenwood kdc-mp642u cd deck but i can't get it to power on in my car
find a wire that is constent hot hook it to the yellow and find an ignition on hot and then hook it to the red and hook up the ground u might need a test light u can get them at an auto parts store or at walmart for about 5.00 or less
Oct 06, 2009 | Kenwood KDC-MP642U
Protect apears in display of my carradio Kenwood KDC 3034
I did not resolve my problem and I defenitly am not going to pay anything to you to resolve it. So if you have the resolution to my problem tell me or do not bother to write to my email adres anymore. Thanks for your answer.
Jun 22, 2009 | Kenwood Car Audio & Video
Kenwood KDC-MP642U Logo
91 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
