I have a Onkyo HT-R8230, i hooked it up to my jvc XL-V114 disk player via rca and the receiver will play for about 2 mins then shut off the stand by light blinks i pulled it apart and dusted it out checked the four fuses made sure every thing has good contact i dont understand it, i checked to make sure all my spkrs were okay and when i turned it back on it made a fuzzy noise that grew louder and louder then it popped and shut off, once again i pulled it apart and checked the fuses they were good i then turned it on with nothing connected and it still randomly shuts off.. i dont understand.. thanks for your time Damian
  • 4,234 Answers
Check the link below for generic information about protect mode as your unit is in that mode. In your specific case, I'd suspect a problem with the coupling caps between the pre-amp stage and the final output stage of the amplifier. There could also be a power supply offset problem. Without taking measurements inside the system, I can't say for sure.
Check out the link and post any additional questions here.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Posted on Sep 02, 2010
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
I have an Onkyo HT-R8230 receiver and I can not get any sound out of the center channel or the subwoofer. The sub will not even power on. It stays in the standby mode and there is no manual on/off button...
The manual is available at retrevo.com.
If you don't have the center and sub defined in the Onkyo they will never work. See page 20.
If that is all set and you still have problems...
To prove the center speaker works, connect it to one of the front channels.
To prove the sub works, connect it via RCA cable(s) to the Tape Out and play something containing deep bass. You should see it come out of standby and hear something, albeit only the deep bass.
Aug 03, 2010 | Onkyo HTR500 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
Zone 2 speakers only work with the tuner - no sound comes out when switched to DVD, Cable/SAT, ect. All of my other devices (DVD player, Satellite Receiver, ect.) run through the receiver. How do I get...
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Jun 10, 2009 | Onkyo TX-SR605 Receiver
Hook up patio speakers and use my cd/dvd/cable/ipod outside only
i'm not sure if this will work, but you could try connecting the rca stereo cables from you cable box to the cd input on the receiver those would be analog. then you could use the music channels at least. as for an ipod maybe sort of the same thing using an av cable instead of the dock;like i said i don't know if it will work but just a thought.
luke
lukeshkin@hotmail.com
Mar 25, 2009 | Onkyo TX-SR504 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
71 people viewed this question
 Grubhead
Grubhead
