I can't get on internet with my Linksys Wireless-G Adapter which is installed on Windows 98 The adapter shows activity I tried different channels,it didn't seem to help.I would appreciate if you have any info on Thank you
  • Niels Boehme May 11, 2010
    First you need to see if your router itself is connected to the internet. Can you log into the admin page of the router by typing the following address into your browser:
    http://192.168.1.1 (Also try 192.168.2.1 and 192.168.0.0.1)
    If that page comes up, the problem is with the router's connection to the internet, not the laptop's connection to the router. You may then need to configure the router.
  • 24 Answers
Also check to make sure the Linksys your using is compatabe with Windows 98. You may need to go to http://www.linksys.com and install Windows 98 drivers.
Posted on May 10, 2008
My cisco linksys ae1000 adapter does not have internet connection
If haven't yet check Device Manager, go to Network Adapters and look for Linksys Wireless Adapter. Check the status of the adapt
Also look for errors codes on anything. Make sure all is enabled or need to install drivers.
If all fails remove adaptor and all drivers for it, restart computer and reinstall adaptor.
Aug 04, 2014 | Cisco Linksys AE1000 Wireless-N USB...
How can I connect my computer to a wifi hotspot I have a Linksys AE 1200 Wireless-n- USB adapter that I installed and it shows that I am connectted but when I try to open internet explorer it says I a
It seems like you are missing the CD you need to fully install this adapter. However, you still can download this data at this link. Since you have Windows XP, click the download link under where it reads 'XP Driver'. Feel free to respond if you need further help.
Dec 29, 2012 | Linksys Computers & Internet
Linksys USB300M cannot install driver for win 98 there is no "installer" on the CD and win98 does not see it for an automatic startup
This adapter is only supported on Windows 98 SE (Second Edition), not older versions of Windows 98. The drivers are already built into Windows 98 SE.
Apr 08, 2011 | Cisco Linksys USB300M Adapter Adapters USB...
My wireless adapter drops the internet signal randomly for several seconds and reconnects. this is a very annoying problem since I am an online gamer. Please help
Try using a different channel, move your antenna's around keeping in mind reflective and blocking walls/metal shelves/trees/etc. You may have a great signal but there are many other issues that can plague a wireless signal while it still shows strong from your adapter/driver.
Use one of the war driving or basic spectrum analyzers to try to determine which channels are least congested in your area.
Sep 25, 2010 | Linksys WUSB300N Wireless Adapter
Can't get my adapter to connect...XP is stuck with Aquiring a network address.
Have had this same problem. This worked for me. Remove the adapter, uninstall linksys, if it is installed, restart the computer, insert the adapter, when found new hardware comes up, let windows use the install wizard to install the adapter. Sorry to say, i have used this method on 5 pcs and it failed on only one. Let's hope yours will also be possitive. Good luck.
May 04, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Making my desktop pc wireless
There is no built-in wireless LAN support in Windows Me, Windows 98, or Windows NT 4.0. Wireless network adapter manufacturers must supply all wireless and authentication functionality for these versions of Windows.
To configure a wireless client computer running Windows Me, Windows 98, or Windows NT 4.0, you must use the wireless configuration tool provided by your wireless network adapter manufacturer. Please see the instructions for the wireless configuration tool to configure 802.11 and 802.1X authentication settings.
Apr 19, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Wusb54g Linksys usb wireless adapter.
This wireless adapter wont work with Windows 98, the reason why your friend encounter an error when trying to install it, it will only work to windows2000 and higher that why you wont be able to install it on that computer, you can check this link and just click on datasheet so you can see the specs of computer in order for this adapter to work http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859843775&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=4377540888B31&displaypage=download#versiondetail
Hope that helps.........
Aug 26, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Wont install
I have only tried this on Windows XP. If you can connect to the web using a hard line you can get this running. Make sure you have internet. Then plug the wireless adapter into the usb port and when windows ask if it can search the internet say yes. That will install a driver for the wusb54gc. Then windows will manage the device. Linksys only has the option to download the installer as opposed to just the driver. What a pain when the installer doesn't work.
Nov 10, 2007 | Linksys Wireless-G WUSB54GC (WUSB54GC-BP)
Computers & Internet Logo
David Payne
David Payne
