Question about JBL ND310 Main / Stereo Speaker
Broken wire terminals! - JBL ND310 Main / Stereo Speaker
  • 158 Answers
Check out parts express.com they have a huge selection of crossover plates and are very reasonable
Posted on Sep 03, 2010
Nissan micra battry turminal is broken car w'not start help me
If the terminal is broken on the battery, you need a new battery. They are full of acid which will leak out. Very dangerous!
If the terminal is broken on the wire lead, you either need a new lead or a clamp on terminal like these.
https://www.bing.com/images/search?q=clamp+on+battery+terminal&FORM=HDRSC2
Go to Bing homepage
Jul 31, 2016 | Nissan Micra Cars & Trucks
Code B0936 what is it
b0936 - When engine coolant is at the proper level, the low coolant switch is closed. When in this condition, battery voltage is applied to the low coolant 1478 input of the body control module (BCM).
When coolant is below the proper level, the coolant switch opens. Because no voltage is applied to circuit 1478, the BCM responds by sending a serial data message to the instrument panel cluster to turn On the low coolant light.
The BCM has an internal timer, which will not turn On the low coolant telltale unless the coolant level is low for greater than 30 seconds. The timer avoids coolant "sloshing" falsely turning On the light.
B0936 Coolant level sensor circuit malfunction .
Check for poor connection at BCM. Inspect harness connector for backed out terminals, improper terminal mating, broken connector locks, improperly formed or damaged terminals and poor terminal to wire connection (terminal crimped over wire insulation and not conductors).
Inspect wiring harness for damage. Check for broken or chafed insulation.
Check for poor connection at the low coolant switch.
If fault is suspected to be intermittent, wiggling harness wiring may help in locating fault.
B
Mar 04, 2015 | 2000 Saturn LW
Battery terminater is brokken and caused car computer to burn out. What can I do to fix it?
for a quick fit just to take you from where you are to the nearest garage changing battery it is as follows. If you can find a long metal screw try to screw through the broken piece of the terminal from top center going through and then go by the battery where the terminal was broken and continue to screw on the base of the terminal. Be careful not to have a very long screw and get through to battery itself. just to be long enough in order to tight by joining together the broken terminal. connect your wire on the terminal and start the car. are you sure you have a burnt computer or is just not starting and is your opinion about?
Sep 01, 2012 | Cars & Trucks
P1676 audi
VAG OBD Error Code Details for P1676 Drive by Wire-MIL Circ. Electrical Malfunction
Aug 31, 2012 | Cars & Trucks
Re craftsman garage opener 139.53960 cannot get power to eyes from right two terminals as shown on drawing. Eruc
Check to make sure it is wired correctly. Solid white wire from each sensor to terminal #2 and white wire with black tracer to terminal #3. Also check to make sure the wires aren't broken or shorted by staples.
Nov 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 2005 GMC 2500HD code P1516, already replaced APP. Still dies, reduce engine speed comes up. What is the next step?
The Throttle Actuator Control (TAC) / throttle body type trouble codes, may be caused by a loose wiring crimp at the throttle body connector, or a broken throttle body circuit.Inspect all related throttle body terminals for a loose wiring crimp. The loose crimp may be difficult to find, and the poor connection will be between the terminal and the copper strands of the wire. Wiggle test the individual throttle body circuits to see if the concern can be duplicated.
Inspect the related circuits for broken wires inside the insulation. The outer wire insulation may look fine, but the internal copper strands may be partially broken. Breaks in the wires usually occur within 1 to 4 inches of the throttle body connector. Wiggle testing may also induce a trouble code to set.
On C/K trucks complete SI procedures for voltage drop on grounds G103 and G104. Grounds G103 or G104 may be loose or corroded. If a terminal crimp or a broken wire has been found, repair or replace only the circuits involved. There is a throttle body pigtail connector available through GMSPO, post back with what you find.
Dec 15, 2009 | GMC Sierra 2500HD Cars & Trucks
97 jetta wont start if i jump a wire to the starter it starts
check the low voltage wire to the starter it runs from the ign key ,most likly broken.adrian;;;
Dec 03, 2009 | 1997 Volkswagen Jetta
How to use a Broken Key - something to grip it for one use.
Take a car battery connect the - terminal to the lock housing make sure the connection is tight. take the + terminal wire it through a switch take the loose end of wire from switch amd touch only the broken key firmley. flip switch on and off for 1/2 second. the wire should have fused to the key. pull key out and get a new key made.
Oct 08, 2009 | Home Security
Problem with SM58, no sound
Most likely cause is tiny copper windings from cartridge to the solder terminals has broken (dropped?). CAREFULLY check for a human hair sized wire leading from the cartridge to the solder terminals that may be broken. Soldering and general repair of these ultra fine wires should be performed by a steady hand and light touch. Once repaired, the capsule (element) itself should read 10-20 ohms when disconnected from the green / yellow wiring....Glen
Jul 05, 2008 | Shure Audio Players & Recorders
Replace wire terminal
normally, if you have a broken thermostat, the wires would just be lying around there. all you have to do is put it back on a new pc of thermostat.
Feb 21, 2008 | Zanussi TC7102W Electric Dryer
JBL ND310 Main / Stereo Speaker Logo
90 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
