Crackling or sparking noise in the air furnace/air conditioner
  • 43,501 Answers
That is probably the electronic air cleaner...they do that when they need to be cleaned or if there is alot of dirt going through...
Check it out and clean it...
heatman101
Posted on Sep 02, 2010
I have a E2EH- 023HB Intertherm electric furnace. The contactors are sparking after furnace is turned on for a few minutes
replace contacters, probably old and pitted (remember points in the distributer on older cars?)
Feb 18, 2015 | Intertherm Heating & Cooling
Power surge now furnace does not work
Look to see if there is a spark clicking noise when you advance the thermostat. If not, the electronic control board is most likely the problem.
Dec 26, 2013 | Dometic Heating & Cooling
How to install a spark ignitor in a gas furnace?
How to install a spark ignitor in a gas furnace? - Fixya
www.fixya.com/support/t15727344-install_spark_ignitor_in_gas_furnace
Jan 8, 2013 - How do I connect the high voltage wire to the Model 990-516 spark - Air ... SOURCE: Goodman furnace wont light, ignitor suspected. Notice.
carrier igniter
Jan 08, 2013 | Heating & Cooling
Heat....Furnace will not start up worked fine last year it is getting power... I can hear I light hum in the furnace but it will not start it process
If its a high or mid efficiency furnace most of the time the sequence of operation goes as follows: tstat calls for heat (R&W at tstat ) ventor motor starts, pressure switch closes, spark or hsi lights pilot or main burners. main blower motor comes on. From your description of a humming noise it sounds like maybe the ventor motor is seized.
Oct 08, 2012 | Heating & Cooling
Myhot water furnace made a loud crackling sound after I turned on the heat and there was some water leaking at the base level of the heater. Also, there were splashes of dirty water on the inside doors.
You have a cracked heating chamber and will need to stop using the furnace, if you haven't already. And call a Service Technician. This is not a DIY repair.
Feb 04, 2011 | Heating & Cooling
I have a rudd hot air gas furnace,ignitor sparks
to carmelmontgo; do you have a smart gas valve sometimes the wire connections get loose. remove wire connector then reinstall. also cleaning a flame sensor will work if the flame sensor is good. I would check the ground connection sometimes contaminated with rust. also I would check the gas pressure with a gas manometer...my email is alpharomeo@windstream.net
Jan 20, 2010 | Ruud UBHC Air Conditioner
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weatherking furnace flashing 5 times.......
Sounds like it it isn't the igniter but probably the pressure switch. You can only tell by the clicking noises as they system goes through it's safty checks prior to the call to the igniter.
Mar 05, 2009 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
