Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
We just bought the house so we are not used to this. Could it be in defrost mode. The freezer is ok but as said the temp goes up a degree and now at 20c
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 02, 2010
Freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Nov 25, 2009 | GE Adora DSS25KSTSS Stainless Steel Side...
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Whirlpool ET18NK fridge does not get cold but freezer is ok. The freezer portion is around 15 degrees, but the fridge wont get colder that about 53 degrees. The house was empty for about 6 months, and we...
If the fan is frozen this would be cause because something in the defrost system is bad. Or you could have a open motor. Make sure the door gasket is sealing.
Mar 08, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Freezer side not freezing
It appears that the defrost bi metal control is hanging up and during the defrost the temp in the freezer is going too high. It is supposed to terminate the defrost at around 50 degrees. This usually occurs in about 20 minutes, if the defrost heater stays on for too long the freezer temp goes too high. Change the defrost bi metal
Jan 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Slow icecube maker
the harvest mode is started when the ice cube reaches around 14 degrees so lower the temp in the freezer or decrease the size of the cubes also make sure the fan vents in the freezer is unblocked. check the temp in the freezer should be around 0 degrees.
Dec 12, 2008 | Frigidaire Freezer Refrigeration White...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
