Question about Texas Instruments TI-5045 SVC Calculator
How do you put paper into this machine - Texas Instruments TI-5045 SVC Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
See the illustrations on page ii of this manual: http://education.ti.com/guidebooks/printer/5045sv/5045sv.pdf
Posted on Jun 27, 2013
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
Overload light keeps coming on but there is only 1 piece of paper at a time
Have you ever "oiled" the machine...get shredder oil and put some into the cutting blades and run the machine in reverse..then put some of the oil on some paper and run the paper thro" the machine.
Nov 18, 2010 | Royal VF1012mx Shredder
I am unable to receive faxes as the machine is indicating a "check paper" although paper is inserted...
Try Two Things.
1st : Switch On The Machien without putting the papers after the machine is ready put the papers in it & try.
2nd : If 1st option not working under the paper tray there is 1 sensor just clean it with surgical spirit using cooton buds,
Aug 03, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Jul 15, 2009 | Schiller Welch Allyn Cardiovit At 2...
I never Used A Fax Machine. I was Given A ''Brother IntelliFaxMC''
if you look at the area where you put your paper to seend ( that is the document feeder ) there should be a diagram of a pice of paper with a corner turned over, if lines are on the top part put paper in dac feeder face up. if lines are on the little corner pice put the paper face down,
if not sher put one pice of paper with lettering in doc feeder press copie of it comes out you got it right. hope this helps
C.W.H. ( typboy)
Jan 23, 2009 | Office Equipment & Supplies
Document jam
I had this totally annoying problem this morning. After looking for any obvious paper jams or small bits of loose paper, I tried several fixes: 1) open front cover, release levers that hold white rollbar in place, roll the bar forward to make sure nothing is stuck behind it, snap levers back in place; DID NOT fix the problem; 2) open top cover, remove print cartridge, look for jammed paper bits, close cover; DID NOT fix the problem; 3) unplug the machine, wait a few minutes, turn machine back on; DID NOT fix the problem. I even unplugged the machine, opened ALL the covers, turned the machine upside down and shake it to see if any paper clips, staples, or other objects have fallen inside the machine; DID NOT fix the problem. FINALLY, I pulled the paper feed tray forward, reached down to the feed rollers, twisted them a few turns, put paper back in the machine, and the "paper jam" message disappeared! This may not work for everyone, but it worked for me today, so I hope this helps someone out there to have a better day.
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper Jam
1-fan the papers many times befor you put in the machine.
2-keep the paper inside its cover in dry place.
3-check for any foreign object droped in paper path(pins-a small pieces of torn paper).
4-check for good condition of paper detecting switches in paper path inside the machine.
Jun 19, 2008 | Canon FAX-L350 Plain Paper Laser
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
Texas Instruments TI-5045 SVC Calculator Logo
96 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
