Question about Whirlpool LGR8648 Gas Dryer
Dryer not getting hot.clothes not drying - Whirlpool LGR8648 Gas Dryer
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 02, 2010
Dryer drying to hot
Check the fan is running, and the filter is clean
Dec 28, 2012 | Bosch Nexxt 500 Dryer
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LGR8648 Gas Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
