Question about Maytag Refrigerators
Makes a kind ofbr sound sounds like acompressor trying to start up doesn,t work
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 02, 2010
What is located in the glovebox of 2003 Kia Sodona that makes a click sound when trying to start?
There are several relays located in that area...it doesn't matter because the relays are probably not the cause of tyour vehicle not starting. If they are clicking, it can only be because they are working - or at least, TRYING to work.
It sounds to me like you need to check the condition of your battery and battery cable connections.
May 28, 2012 | 2003 Kia Sedona
Dodge caravan 1996 doesnt start
It is very hard to help you when you give no details. But if it doesn't do anything when you try to start it you probably need to charge battery or get new one. If it is trying to start and doesn't sound weak then you need to have someone look at it. It doesn't sound like you would want to do anything yourself but if its not the battery, it doesn't sound good. Good luck
May 06, 2012 | 1996 Dodge Caravan
Rear right speaker doesn't work, no matter what we tried. We switched the speaker and cables with one of the others, but just that position (surround right) doesn't work.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Sep 09, 2011 | Spherex Xbox 5.1 Surround Sound System...
Hi,I got an Ariston Margherita 2000.It does work well,but the end of the cicle the water doesn`t dissapear from drum.I tried everything,but nothing happend. Many thanks. Zsolt
Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Ariston Technologies Washing Machines
I cant get my lincoln ls 01 to start, it wants to turn over but doesn't turn on, before the problem the car was making a loud knocking noise that got worse over time then the car shut off and wont turn...
Honestly, that sounds bad-loud knocking that gets worse, then no start-does it sound normal when it cranks? Does it crank freely? Is your battery in good condition? More information is needed...
May 23, 2011 | Lincoln LS Cars & Trucks
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Computer can't find sound device
START - My Computer (RIGHT CLICK) - Properties - Hardware Tab - Device Manager button - click on the sound, video and game controllers - on the drop down menu you should see sound codec - either right click and UPDATE DRIVER - or delete sound codec’s and restart, XP will install suitable sound drivers.
If that doesn’t work then try installing sound drivers from the computer manufacturer.
If you have a big X on the sound codec or your third party drivers than it’s a hardware issue.
If replacing the drivers’ doesn’t work then it's a hardware issue. If you have onboard sound card then you will need to replace the mother board. I hope it's under warranty.
Jun 30, 2008 | Computers & Internet
Sound device not working
Windows XP
Jun 29, 2008 | Computers & Internet
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
