My Aspire One Series computer (8.9?) works well with the AC power, with the battery on or off. However, the battery (UMO8A52) all of a sudden stopped charging. pleaswe help
  • anast3925 Sep 03, 2010
    The Solution 1, did not work. Where I can buy the appropriate bettery that can be delivered soon because in a week I am leaving for a long trip. Actually is UMO8A52 the appropriate battery? ( my computer does not indicate the correct model of "Aspire One Series").
  • anast3925 Sep 08, 2010
    It is not easy to find a UMO8A52 battery. Can I buy a UMO8A51 one will it work?
  • 1,472 Answers
Anast3925
If you are needing a replacement battery you can ether go to this link to see if there is a local reseller in your area that my have have a replacement battery that you can purchase.
Acer Resellers Near You
You can also call Acer directly at 408-533-7700 to see if you can purchase a battery from them.
Also note if you have had your computer less than a year you might check with Acer to see if you can get it replaced through an RMA as most batteries have a 1 year warranty.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 03, 2010
    President:
  • 3,278 Answers
Hello.
Disconnect the AC power and remove the battery. Use compressed air to clean the contacts where the battery is connected and reinsert. If the battery still does not charge, it could be faulty and need to be replaced.
If a friend has the same computer, swap batteries and see if another battery works.
Hope this helps.
Posted on Sep 02, 2010
  • NinaE Sep 09, 2010
    You could find your battery on eBay, etc. But, your best chance to find is at the Acer website.
    No power from battery to laptop
    are you installing it with correct polarity
    is one of the battery terminals in the laptop damaged so that it is not making contact
    May 22, 2017 | Acer Computers & Internet
    My acer aspire 5610z series does not trun on even with the power cored followed rebooting trouble shooting nothing wrked i think it made it worse what do i do
    1. Check your power cord & adapter. 2. If its working then check the battery, reseat the battery & check. 3. If available then check with another battery 4. If no, then remove the battery & switch on the PC in AC mode. 5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. 6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. 7. If still no display, connect an external monitor, check if display is comming. 8. If Display is coming then your LCD need to replace.
    Aug 23, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
    Hello there, i have problems whether plugging the AC supply into my acer aspire 6920G laptop. when i plugging the AC, the laptop will suddenly shutdown, then boot up again. but when im using battery, it...
    I am sure its totally fault of your OS. Becouse some when ac working well, some where battery. your OS does not recognised your power control properly. Try to use single OS and get batter result. if done thumbs me.
    Dec 16, 2009 | Acer Aspire 6920 Notebook PC
    Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
    Power
    subsystem
    ACPI 2.0 CPU power management standard: supports
    Standby and Hibernation power-saving modes
    71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
    Acer QuicCharge™ technology
    (for Aspire 5600 Series):
    • 80% charge in 1 hour
    • 2-hour rapid charge system-off
    • 2.5-hour charge-in-use
    90/65 W AC adapter
    Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
    Aspire 5003WLMI No Power
    you have a hardware problem which would require opening your laptop. i suggest you bring it to a computer technician who can do the repair for you to avoid further damage.
    Aug 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Toshiba Tecra M2 Series
    Was the laptop on when it turned off? It may be a PSU problem but we can determine this by removing the battery. Make sure you disconnect the AC adapter while your removing the battery. Inspect the contacts and make sure`there are no black marks or any other dirt. Leave the battery out and plug in your AC adapter. Try the power again.
    There are a couple of possibilities in terms of problems that I can suspect so far. Did anything out of the ordinary happen when the computer just stopped working all of the sudden.
    1. Battery has failed and short circuited the contacts 2. Power supply failure 3. Motherboard could have failed in style. 4. Power contacts for the AC adapter are damaged.
    Jun 15, 2008 | Toshiba Tecra M2-S730 Notebook
    Laptop was working fine, but doesn't turn on anymore...
    a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
    To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
    Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
    Computers & Internet Logo
    119 people viewed this question
    David Payne
    David Payne
