Question about Pioneer SD-P50A3-K TV
TV Turns off automatically
Just can not turn it on anymore. never had theis issue before
  • Anonymous Jun 07, 2008
    T.V. turns off automatically and won't turn back on it does like a circuit breakage it trips
  • Anonymous Jun 08, 2008
    tv will turn on and clicks and turns off immediately like a circuit breakage
I want jet way (amd chip set) sound & graphic driver
Posted on May 11, 2008
    President:
  • 2,712 Answers
Could be a problem with the flyback /auto transformer / powerboard. I'd get those checked first..
Posted on May 10, 2008
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
2 Suggested Answers
SOURCE: TV Turns off automatically
i think some component is getting over heated inside so you are facing this type of problem ....
the component may be transformer,capacitor on some circuit board ...
due to this temperature variation you tv will turn off ...
or may be some IC(intergrated circuit ) is gone ...
there will be one Video IC if it is gone means also you will this problem ...
if it is gone it will get heated very shortly so the tv will turn off due this variation in temperature ...
just have a check with these components.......
Posted on Jul 04, 2008
TV automatically turns off. unpluged the tv and
Hey i am having the same exact problem with my same exact tv. If you have already solved your problem I would love to know how u did it. I know you posted this a long time ago but if you havent gotten it fixed yet, if I fix mine i will let you know. Thanks.
Aug 03, 2010 | Toshiba 65H84 65" Rear Projection HDTV
The tv turns on and the large circuit board just
Sounds like you have Bad FBT Flyback Transfomer
to be sure you need to remove back and see where arking is coming from? Mats Electronics has Parts for this TV.1-800-628-1118 Let me know if you need anymore help.
Mar 23, 2010 | RCA HD56W58 56" HDTV
Sony wega tv that turns on and automatically turns off
6 flashes is a thermal fuse blown in the lamp chamber. If you are not familure with tv repair then you might want to leave it to a pro. but to get the right part number for the kit i need the model you have. If you want the kit part number post back.
Sep 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
RE: Sharp Aquos LCD TV, MODEL LC-37D40U Tried to switch the TV on via remote, and I hear the TV turning on, but then it automatically turns itself off again. Tried it several different ways using...
A component is shorting out, and the TV is auto turning itself off for protection. Usually it is a shorted out horizontal output transistor. Only a tech can fix this.
Nov 13, 2008 | Sharp Televison & Video
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Blue and Green Bar
run magic focus, If you get a error 4 during the magic focus, that is often an issue with the convergence
Feb 01, 2008 | Hitachi 51F500 51" Rear Projection...
Problems with my TV
change your bulb in the TV. That should do the trick
Jan 23, 2008 | Televison & Video
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
TV turns off
It sounds like you might either have a bad power cord or you might have an over heating issue. Some times the TV will automatically shut off if it senses a fan issue or it starts to overheat. What technology is your set? DLP, LCOS, DILA...? If its under warranty I'd suggest to get someone out asap to take a look at it.
Sep 13, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Pioneer SD-P50A3-K TV Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
