Question about GE 24 in. GSD2600GBB Built-in Dishwasher
I have a GE Potscrubber 720 and there is water in the bottom of the dishwasher and I tried to clear it by starting a cycle and it still keeps water in the bottom of the washer. When I run a cycle there is caked on soap on the inside door and dishes and the dishes are filthy. I found a long thin piece of metal by the drain it is long and straight and a break on one end and an "L" shaped bend on the other.. Any ideas where to start looking for problems? As I have no experience in repairing dishwashwers. Thank you John
SOURCE: dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Posted on Apr 26, 2008
SOURCE: GE Nautilus
Smoking from GE (Model:gsd3725f00bb) dishwasher
We moved in an old house, the dishwasher had been installed. but today we found smoking from the dishwasher and smells burned plastic. Could you have any resolution for me? or this problem is popular on this model?
Posted on Sep 17, 2008
  • 276 Answers
SOURCE: Dishes not being rinsed thoroughly in our GE Nautilis Dishwasher
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
SOURCE: GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Posted on Jan 20, 2009
SOURCE: Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Posted on May 10, 2009
Ge potscrubber dishwasher #2230
try removing the bottom panel with washer off look for small fan on motor turn to make sure it is turning free. This happens a lot with the snowbirds in Fl. Simple fix.
May 15, 2014 | Dishwashers
Dishwasher won't drain at the end of the cycle
Whenever an appliance does operate its pumps/valves heaters correctly for part of a cycle then doesnt at another point, it is a problem with the controller of the sequence in the cycle.. On older devices this can be a rotating knob that slowly runs to end of cycle triggering events as it turns, by tripping blade switches near the rotating item. On these the switch trigger points can be inspected and sometimes repaired. On newer items the cycle is controlled electronically, and you have to replace the whole control unit, which is usually a large expensive part that includes the display and all buttons. Try getting a used control unit from Ebay and swapping it out, or consider replacing the whole appliance.
Dec 14, 2013 | GE Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
My GE Potscrubber 1200 cuts on perfectly and
probebly you dont have enough water coming in start the dishwasher,when it starts washing dump a bucket of water in the tub.if it starts moving replace the intake valve
Feb 26, 2010 | GE Dishwashers
GE Potscrubber 720 attachment
i got mine from the local Home Depot. its called a "bubble stream Large Snap Fitting"
Nov 22, 2008 | GE 24 in. GSD2600GBB Built-in Dishwasher
GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Does it sound like it is trying to drain or is it just silent?
Jul 08, 2008 | Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwasher
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
GE 24 in. GSD2600GBB Built-in Dishwasher Logo
104 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
