Question about ViewSonic ViewMate Keyboard
KP-102 Viewmate Keyboard
I have had this keyboard for sometime. I never received a Disk or rom with it. Some of the Multimedia Keys work, others do not. I would like to see a manual and have the correct Drivers installed for this keyboard.
Thanks in Advance
Jack
jackjj@charter.net
2 Suggested Answers
SOURCE: I accidently hit the sleep button on my keyboard
Press, but do not hold, the power button one time. the system should start back up and resume windows just as you left it.
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Nov 16, 2010
  • 8 Answers
SOURCE: ViewMate Keyboard: when I press shift 2 I get inverted comma. donot w...
you need to change the keyboard lay out install US if the machine is from US and UK if bought in the UK goto regional settings etc
Posted on Sep 14, 2011
Changed batteries on keyboard and now wont sync. Cant see a sync button on the keyboard so dont no wat to do
Hi.
You should find the sync/connect button underneath the keyboard. You must also press the button on the receiver.
Regards.
Jun 08, 2011 | ViewSonic ViewMate CW2206 DHCW2206...
Some of my function keys dont work when i use them
Generally, most keyboards should work just fine when plugged in. Often if a keyboard has multimedia keys these may not work until driver software is installed to let the keyboard use them.
With laptop keyboards sometimes dust or other material may get under them causing keys to not function correctly. Compressed air can blow out debris if this is the case. Just read the instructions
on the compressed air before using it to keep from damaging componnents.
Apr 29, 2011 | ASUS 90-A4C1K1000 Keyboard
Keyboard is locked up. Looks like Function Keys
is scroll lock on? if so turn it off and engage number lock.
Aug 29, 2010 | ViewSonic KP202, VIEWMATE OFFICE KEYBOARD...
May 16, 2010 | ViewSonic ViewMate Keyboard
The space bar won't work unless pounded on (other keys work just fine). how can I fix this?
You have a defective keyboard spacebar. Just get a
replacement. I have a problem similar to what you got.
Since it was delaying my work, I have it replaced. Anyway, keyboard doesn't cost much. There are a lot
of choices that you can buy at a bargain.
Nov 11, 2009 | ViewSonic ViewMate Keyboard
Keys not working
Try to unplug the keyboard, restarted the computer and reconnect the keyboard once the computer is fully restarted.
Then go the Control Panel, double-click the keyboard icon. Select the Hardware tab and make sure that the "Standard 101/102 key or Microsoft Natural Keyboard" is highlighted or selected.
Aug 17, 2009 | Logitech 967233 Keyboard
I have a Microsoft multimedia 1.1 wireless keyboard but i cant use the shortcuts in the keyboard
usually to use the extra shortcut keys you have to load on some software, from microsoft's website or from the disk that came with the keyboard, without it, the keyboard will only work in a basic manner
Jul 08, 2009 | Microsoft Multimedia Keyboard/Wireless...
Keyboard symbol keys now showing as accent keys
Or maybe you can try to hit the control en shift button at the same time and then try again.
Jan 26, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keys won't repeat
You may be tripping over an accessibility option. Try this:
1. Click the Start->Control Panel menu item.
2. Click Ease of Access.
3. Under Ease of Access Center, click Change How Your Keyboard Works.
4. If Turn On FilterKeys is checked, UNcheck it.
5. Click Apply or Save.
Dec 11, 2007 | ViewSonic ViewMate Keyboard
ViewSonic ViewMate Keyboard Logo
46 people viewed this question
Top ViewSonic Keyboards & Mice Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Keyboard and Mice Expert? Answer questions, earn points and help others
