Question about Whirlpool Dryers
My drum will not turn when you turn the dryer on it just makes a whining sound
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 02, 2010
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
The drum is hesitating and making a whining sound
sounds like the belts are badneed changing
Feb 19, 2010 | GE Dryers
When the drum is turning during a drying cycle it sounds like a whining noise is going on...I don't think a belt is broken
WHEN THE BELT IS BROKEN, THE DRUM NOT WORK. I THINK YOU NEED CHANGE SHAFT SUPPORT, BEARING SUPPORT AND BEARIN DRUM.
Jan 29, 2010 | Dryers
Maytag pyet244ayw---the dryer would not turn off.it had to be manually shut off. now, it turned off during a drying cycle. i can hear a whining sound when i tried to restart it.
Could be the belt.
Disconnect power.
Using a putty knife, slide it under the top and front panel of the dryer. There is one clip near each front corner. Pull up on the top panel while depressing the clips.
With the top up, you can see the drum and the belt should be around it and tight. You should be able to rotate the drum with your hand with some resistance. If the belt is not present then it is probably broken and under the drum. If this is the case, the whining you hear is the motor turning under no load.
Please post if this is the problem or if other to assist others with a siimular problem.
Dec 15, 2009 | Maytag PYE2300AY Electric Dryer
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Dryer makes a whining noise when drying
The belt is not the problem but more likely the drum rollers or drum bearing will need to be replaced.
Jan 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Open Questions:
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
