Question about Sharp XL-UH242 Shelf System
My SharpXL-UH242 stereo shuts itself off whn the volume goes above a certain point (like 20) This goes for CDs and AUX inputs. PLease help!
  • 11,896 Answers
This is a self-protection circuit in these things. I hate them myself. It's made so the systems or speakers don't blow. There is usually a wire inside you can remove to unplug the self-protection but not sure where it would be exactly in your unit. If you bass is turned down lower, usually you can turn the volume up a little more without it going out.
Posted on Sep 02, 2010
Why does my Pioneer DEH_150MP skip when it's playing cds, aux, and radio at a certain volume?
It can't skip on radio. I would theorize if you have a heavy bass system you either have a loose connection or the faceplate contacts are not good and vibrations are causing a temporary loss in connectuon. The other option would be a speaker that is shorting at a specific volume. The short is causing the internal amp to shut done (until the short is gone) to protect itself. Disconnect all speakers and connect just one until the problem returns. This way you can eliminate which speakers are good. Also make sure the ohms f your speakers are within tolerance of the radio...no lower than 4 ohms each.
Oct 11, 2016 | Pioneer Car Audio & Video
What is code on a rca 4 device remote to control sharpxl-uh242
In the likely event your RCA remote is universal, you can use code search to find something that works. If a search through all codes stored in the remote fails, you may have o try a different universal remote.
Jun 01, 2016 | RCA Televison & Video
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Stereo in my Fiat punto 2007 model has an AUX function. Can i connect cable to AUX Input to run MP3 player via ear peice output?
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Jun 17, 2008 | Blaupunkt Car Audio & Video
Cd player cutting out when volume is high
you prolly need a new voltage regulator
May 14, 2008 | JVC KD-G720 CD Player
I would like to run my tascam CD-GT guitar trainer through the speakers. Does the aux. speaker inputs above the antena connections have volume control through the stereo?
Hi Gargoyle005,
Most Aux jacks have a base level, other then adjusting the level on the trainer your would have to control the volume with the standard volume controls.
Cordially
Jon
Go Ahead. Use Us.
Apr 21, 2008 | Audio Players & Recorders
Volume turned to MAX for almost no sound from record player
You will need to purchase small box that converts your phono magnetic cartridge level output to a higher line input level before it goes into the TV input jack. Radio Shack used to sell a small amp for about $20 that was made just for that purpose and was called a stereo pre-amplifier and was model number SPA-50 and it plugged into the standard wall outlet to get power. Back in the "old" days when phono magnetic cartridges first became popular some of the older home stereos had only the ceramic phono style inputs (or an aux. input) which were about the same input level as a tape input or aux. input (or TV input) and so you would have to use one of these adapters to boost the newer magnetic cartridge signal up to the same level as a ceramic cartridge in order to use a new style of phono. This will fix your problem if you can find one at Radio Shack or some other place, perhaps on the internet. Hope this helps you.
Nov 20, 2007 | Sony STR-DG510 Receiver
Stereo volume doesn't effect Aux input volume
in a car stereo system, when you select line input, it usually assumes the device you are connecting has its own volume control. if you really want to use your cars volume knob, an FM transmitter might do the trick.
Nov 03, 2007 | Jensen MP7610 CD Player
Audio Input Problems
buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
Jul 29, 2007 | HP Compaq nc6220 Notebook
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Sharp XL-UH242 Shelf System Logo
146 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
