Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Replace protective platic panel in an lcd tv
Where can one find a replacement panel for an lcd tv...the plastic protecitve panel on my lcd tv is scratched...can you advise???
LCD TV 42 Samsung fell from the wall fix and broke.It costs 40,000 to repair.Is it worth or go for a new one
Posted on Sep 13, 2009
  • 395 Answers
Unfortunatly the protective screen is not available as a seperate part, it is the whole LCD panel that needs to be replaced. if the TV is the LC-42d62U then the part number is R1LK420D3LF21 and can be found at for $2362.80.
Posted on May 11, 2008
There are screws in the power window / door lock panel, speaker grill and under the little plastic squares. Remove all, there may be more panel screws once you remove those pieces (they hide the screws holding the panel). Then pry the panel off. There are usually some plastic clips that will likely snap. Also, some silicone calk is holding some plastic page like material in place. That silicone never dries so that can be a mess.
Replace,ent platic clips can be found at pepboys or the dealer. Cheaper at pepboys or even eBay.
Jul 30, 2014 | 2003 Ford Crown Victoria
Looking for screen replacement for LG LCD model 42LK450
You could try disassembling it, because in most cases on lcds there is the very delicate actual panel, and then a thin piece of protective plastic. If there is, you can simply replace that. It all depends on whether the lcd itself is damaged.
Without more information, it's difficult to tell how hard it'll be to do. It can also be quite expensive (usually around the original cost of the TV for a new replacement screen). If you have a LCD projector set, that too can be quite expensive unless you're able to obtain a rebuilt unit somewhere.
I would recommend selling the parts on ebay.
Sep 20, 2011 | LG 42LC2D 42 in. LCD HDTV
Cannot locate LCD controller board #V420B1-C04 for Sharp model #LC42D43U
the lcd controller is also called the T-con board. it is attached to the back of the screen on the top middle of the screen. Under a platic or a metal shield. you can get parts for this TV at
Jun 02, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
Tv goes blank after a few minutes. Turn tv off and back on and it will come back on for a few minutes and go blank again
You are having trouble with a thermal protection switch in the TV. The power supply will have to be replaced. It is also possible that your lamp (tubes behind the LCD panel) are going bad and drawing too much current and causing the power supply to protect itself.
May 06, 2011 | Insignia 42" LCD Flat-Panel HDTV
Replaced cartridges & no ink on paper
Be sure to check that you removed the protecitve film from the ink print head cartridges...
Jul 14, 2010 | Epson Stylus C84 InkJet Printer
Screen was hit with a wii remote :( the actual screen isn't marked up but the picture behind it is striped on the right hand 1/3 section of the can also clearly see the exact spot hit by the...
unfortunately the panel sounds like it cracked, that cannot be repaired and panel replacement will cost more than new tv. They make clear plastic protective screens for lcds websites like tv-armor and the like sell them.
Jan 23, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Wiimote hit my 42" lcd can it be fixed?
The LCD panel which is responsible for the picture is toast. You will need to replace it. You can have it repaired using a TV Repair guy but often it costs as much as a brand new LCD.
I recommend just finding the best sale you can and buy a new one.
My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Sep 08, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Our Son hit a plastic ball into the face of our new Toshiba 40RV52U LCD display. We now have an area that looks like a splat and a hole in the picture. Is it possible to repair or replace the LCD screen?...
unfortunately it can't be repaired the entire panel will need to be replaced, most times the cost of the panel is as much or more then the cost of the tv. My son broke our 42" lcd after had it for only 3 weeks! Not covered under warranty...we had to replace tv. FYI there are companies that sell a clear protective screen for LCDs I bought one and it works great! One such website is but you can google and find alternatives.
Apr 30, 2009 | Toshiba 40RV525U 40 in. LCD TV
Wii Controller into TV - - Very Bad
An LCD TV, from front to back, consists of these layers:
protective film - <1mm thick
liquid crystal cells - <1mm thick
charge screen - <1mm thick
backlight panel - 5-10mm thick
metal heat spreader - 2-5cm thick
controller board - 1mm thick
Your son most likely damaged the liquid crystal cells...
Unfortunately unlike normal TVs these are precision assembled, and there isn't much you can do to fix it.
It is possible to replace the screen, but it involves replacing the entire unit, from protective screen right to controller board. In other words, almost everything except the plastic case.
Unfortunately I think the tv is busted permanently, and it will cost more to repair than to replace.
Dec 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hdtv lcd 40 in. broken screen face
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,024 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
