Question about Samsung Digimax D53 Digital Camera
Blury image it just happened, the image looks blury through the lcd, everything else is ok
Change the setting go to the ocd. and change it to auto..
Posted on May 27, 2008
My Toshiba laptop monitor shows blury images and icons, how can i fix it?
Run a thorough virus check. If no virus found then:
Try System File Checker. It finds and replaces corrupted system files. You may need a copy of OS.
Go to Start > Search > type cmd ENTER. At command prompt type sfc / scannow ENTER.
Oct 09, 2012 | Toshiba Satellite Pro L300 Notebook
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
Everything is blury have to set screen resolution to 800by600 pixels to try too make any thing out.
Connect the monitor to a laptop -- is it still blurry?
If so, then the monitor is the problem.
If not, then your computer (the video-card?) is the problem.
Oct 31, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Picture Image Becomes Blury When Recording
i had the same problem i just gave the camera a good smack and it was all good. lol
Apr 19, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
My mpc laptop turn on but screem not what can i do
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 17, 2009 | MPC Computers TransPort T3000 Notebook
Cyber shot dsc-f717 lcd blury and takes blury pictures
Blurry image on camera mode is problem of defective CCD imager and required replacement.
Sony will repair your DSC-F717 free of cost as per announced scheme of CCD imager problem in few models and DSC-F717 is in list.
Click Sony CCD Support for details and instruction of shipping.
Good luck.
Dec 19, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Sony Wega 42" LCD KF-42WE610 Color Problems
Check this "blue dot" link. If this is you issue sony will cover it.
http://esupport.sony.com/US/perl/news-item.pl?mdl=KF42WE610&news_id=237
Mar 03, 2008 | Televison & Video
LCD oddly discolored but final image OK
Don't rush to the store. CCD's in video cameras have it, My Coolpix has it. It has something to do with the way information is written to or read from an LCD or CCD. And although it looks bad, it's perfectly normal. Use an early days $50,000 broadcast CCD videocamera to record a person welding and you'll get a perfectly vertical white line in your image. But as you said: It's not in the actual image of the Coolpix (although I wouldn't know if it will show up when you make a picture of someone welding).
Sep 12, 2005 | Nikon Coolpix 5400 Digital Camera
Samsung Digimax D53 Digital Camera Logo
53 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
