Question about Dryers
Why does my GE Dryer Manual Model DWXR473ET5WW turn on then goes off immediately
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 02, 2010
What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 19, 2012 | GE Dryers
My GE gas Dryer does not iginite and get hot. It turns or tumbles but does not get hot. Checked gas line everything ok with gas line. please provde step by step instraiuctions to replace the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Dryers
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
Does anyone have the schematics or manual for a GE Spacemaker WSM2420TCAWW Stackable Washer and Dryer.
I have this model with model#WSM2420TCAWW tag inside the dryer however the use and care guide and manual that came with it has Model#WSM2420S on it. Try searching this. If you dont have any luck I can send you a copy with your e-mail. Good luck dc
Oct 24, 2010 | GE Spacemaker Washer and Dryer Electric...
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
Aug 14, 2009 | GE Dryers
Dryers Logo
169 people viewed this question
Top Dryers Experts
