I've had the bose companion II computer speaker system and coming from one of the speakers is a loud buzzing sound. The volume control round also has been acting up...the orange light is on and I can't turn it on. What do I do??
    Sergeant:
  • 357 Answers
Send it back to the manufacturers. The price you pay for that company, they can certainly give customer support!
Posted on Sep 03, 2010
I get sound from the laptop but no sound when I plug the external speaker in.
click start control panel sounds and audio volume advanced speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary setting adjustments
hope this helps
Oct 23, 2011 | Bose Companion 3 Series II Multimedia...
I just bought Bose Companion 2 speakers which I don't know how to connect to my HP Pavillion desktop PC. The pdf instruction booklet does not help. There are multiple jacks (6) at the back of the tower...
You need to connect the speakers to the green jack in your PC.
Check your system sound volume setting to make sure it's not set to MUTE or the volume slider is on or near the lowest position - you don't specify what system you have on the PC so I can't give you an exact pointer but Volume Control generally is found under Programs -> Accessories -> Entertainment.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Bose Companion 2 Series II Multimedia...
Have bose Companion 2 speakers. Can't get any sound.
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 07, 2010 | Bose Companion 2 Series II Multimedia...
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
Speaker to sensitive to bits.
you can use another product with bose
Apr 09, 2010 | Bose Companion 2 Series II Multimedia...
Bose Companion 2 speaker has crackly volume control - simple job to clean if I could get the unit apart!!! Any advice would be appreciated, thanks.
The problem with the crackly sound is caused by dust or dirt in the Reostat that controls the volume. it needs to be cleaned, there are a couple of different types of Cleaners that you can use. Just be sure its safe for the application. (of course the cleaner part is common sense)
Nov 16, 2009 | Bose Companion II Computer Speakers
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Mar 10, 2009 | Bose Companion 3 Series II Multimedia...
Speakers only play cd's
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Feb 24, 2009 | Bose Companion 2 Computer Speakers
48 people viewed this question
 Grubhead
Grubhead
