Question about Hitachi Travelstar 5K100 HTS541060G9SA00 60GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26923FT) Hard Drive
Seems to power up ok but bios does not see it. no nasty grinding noises like the heads have come off
  • 54 Answers
Make sure sata/scsi is enabled in bios usually by pressing f2 some boards come from factory to read ide and sata diabled make sure it is enabled
Posted on Sep 02, 2010
  • TechRx Inc http://techrxgb.com
    Possible NVRAM corruption on the hard drive's PCB. You could try sending it to a data recovery company such as TechRx, Inc. (www.techrxgb.com) to have it reviewed free.
Abs light on/grinding and clunking in turns on front left side of 2003 ford explorer
Sounds like left front loose wheel bearing knocking ABS sensor out of range causing ABS light to come on and causing grind noise at same location. Grinding noise is probably rotor rubbing on calipar.
Aug 27, 2014 | 2003 Ford Explorer
Grinding noise in front end
Have the brake pads checked, if they are ok you may have a faulty wheel bearing.
Mar 27, 2014 | 2007 Ford Edge SEL Plus
Grinding noise when accelerating
HI If your bike is chain drive, look at the chain tension, the chain could be hitting the gear box case. If you primary sprocket is worn the the chain could be jumping teeth If you have a shaft drive then inspect the universal joints and the differential oil level
Feb 02, 2014 | kawasaki Motorcycles
Grinding noise after changing cartridges
When you put new carts in, it will then clean the print heads. There is an unbuilt system for this in the printer, it will purge ink through the heads to clean them. It does make funny noises sometimes.
Sep 05, 2012 | Epson Stylus Photo 1410 Printer
Very loud grinding noise on the A200 std18-70 mm kit lens when turning off and on
My Sony a200 camera also makes a nasty noise when switched on, and also when I switch it off.
Oct 19, 2010 | Sony Cameras
Grinding noise from power steering pump or pullie
Please - for safety sake take your vehicle to a shop.
Apr 03, 2010 | 1999 GMC Safari
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Seems to be hold back and making slght crunching noise
If you are experiencing grinding noises and a power loss, I would look more to the power train and related components. Transmission, wheel bearing, brakes hanging.
With the engine off, I would push the bike slowly to determine if you are able to detect a grinding noise and if there is any resistence when pushing it.
Bill
Nov 17, 2008 | 2005 Aprilia Mojito Custom 125
Open Questions:
Computers & Internet Logo
176 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
