Question about Kenmore 463845504 Grill
When i turn two burners on it works good with all four burner the gas pressure drops
  • Kenmore Master
  • 43,501 Answers
The gas pressure regulator is either too small or it is not opening up all the way....
If it has worked in the past then the size is right and so it is going bad and needs to be replaced...
heatman101
Posted on Sep 02, 2010
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
Jan 11, 2011 | Jenn-Air JGD8130 Gas Cooktop
I have a Viking gas single oven with four burners. The burners work fine but the oven won't fire up. I smell gass an I see a glow under the oven but no heat. But if I turn it to broil I get some heat but...
I had the same problem with the single oven, It the voltage feeding the oven, it like to be 120 or above if it drops below 120 then this problem occurs. I had ever thing checked, gas pressure, and the oven. Electrician installed a voltage regulator on that circuit.
Dec 30, 2010 | Viking Ovens
I just attached a new tank of propane. The line has a good seal and I can get the pilot burner to light. The problem is when I turn on the second burner the pressure drops significantly and the burner...
I can make a few suggestions.
If this is an outdoor grill, I have had insects (especially spiders) nest in the gas tubing causing a restriction. Start by removing the burners and working your way back to the main gas line.
Gary
Dec 12, 2010 | Garden
This si the second time I have had a problem when I changed tanks. It started working the first time but not this time. The tank valve is open and the pressure guage is in the green, until you tirn on...
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Sep 06, 2010 | Brinkmann Charmglow Stainless Steel LP...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Burners will not disengage after shutting off Hot Water.
Ok the way this system works is from a pressure and flow switch. The pressure switch picks up the slight drop in pressure when the hot side water is turned on then turns on the burner. The flow switch measures the amount of water flowing and adjusts the size of the burner to the amount of water flow. So a couple different things might be happening. The flow switch might be sticking causing the water heater to throttle down the burner but not off when the water flow is off. Or the gas control valve might be by-passing gas when off causing the burner to stay on even when the demand is off. Run the hot water on high demand then turn the water off. If the burner is still on try banging on the water heater with your hand and see if the burner shuts off completely. If it does the gas control valve might be by-passing. You would also need to check and see if the pressure/flow switch is giving any voltage signal changes when the water flow is off. These tankless water heaters are more comlplicated to work on than a standard water heater and you may need a professional's help...good luck
Sep 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Only one of the burners is firing
check for blockage in the gas orifice as well as the burner
May 02, 2009 | Hayward H Series
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Gas Burner spark on other location
When you turn a burner to the light position, all burners should spark. If one is not, clean burner head area where the burner is not sparking. (dirty from boil overs)
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Whirlpool Drop-In rear burners shut off
The gas line was stuck clean nozzle w/ small neddle and clean burner set the edge of the burner in order complete gas will be burn.
Jan 04, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Kenmore 463845504 Grill Logo
62 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
