I have a plasma pioneer tv pdp-502mx. 2 problems 1. gets no sound 2. there is a line across the tv and it gets worse the longer the tv is on .....bad middle left distorsion of color. pls help....Thanks,.....Sam
  • striker217 May 10, 2008
    tryed that
  • striker217 May 14, 2008
    Coolguy,
    Solution didn't work. Any other suggestions?
    Thanks,
    Sam
    Genius:
  • 3,422 Answers
try a hard reset by unpluging it for 4 hours and then plug it back in.
Goodluck..
Posted on May 10, 2008
  • 1 more comment
  • Priya darshan May 10, 2008
    Usually this problem is associated with no picture other than the horizontal line. It is an indication of the vertical deflection amplifier failing.
    BUT, since you have a picture, it means you still have the vertical deflection. However, it could still be a bug in the vertical amplifier. It could also be a bug in the raster generator.
    So,
    ONE: Do a hard reset of the tv. Unplug the power cord for 4 hours, then power up again.
    TWO: Do the whacking test to make sure it is not a loose connection or cold solder joint somewhere in the works.
    THREE: Unplug all the inputs on the back or front of the set and reinsert them again; do this two or three times. It will make sure of a good connection. The multiple insertion cuts through any micro corrosion on the connection points.
    FOUR: Try a dvd player into the video inputs. Do you still have the line? This means the line is coming after the video input circuitry and is not associated with the tuner or rf input area of the tv.
    goodluck..
    Please don't forget to rate or accept the solution
  • Priya darshan May 14, 2008
    Well now the only solution is to get it repaired.
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Pioneer PDP 502MX
Overload fault in the power supply or a short in one of its load circuits. In some cases, the low voltage (including B+) will just be reduced to a fraction of their normal value as a result of an overload on one of the outputs - usually the main B+.This may be caused by a shorted rectifier in the power supply, flyback, or even the yoke, but check the the loads first.
Jul 20, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Yellowish-Green Blotches on Pioneer PDP V402 Plasma Display
i have a pdp-v402 display was wondering if it can be hooked up to my tv if so how
Jan 05, 2009 | Pioneer PureVision PDP-V402 40 in. Plasma...
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
PDP-4330HD
This exact same problem happened to me 2 weeks ago on my Pioneer PDP-4330HD, and it did indeed turn out to be the power supply. The good news is, you can get it fixed for free, because Pioneer actually recalled the power supply in this plasma and others a couple of years ago.
Here is a link to the announcement on their website concerning the recall. They say that they will do a free in home replacement of your power supply, but when I called the local pioneer repair place, I was told I would have to wait three weeks for an in-home appointment. I ended up taking it in myself, and it was fixed for free 2 days later. Now it works perfectly.
Here's the number to call Pioneer in case the link goes down:
1-800-421-1404
Nov 10, 2005 | Pioneer PureVision PDP-4330HD 43 in....
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
