Question about Dei 504d Double Guard Shock Sensor Alarm
I have a stinger car alarm, the battery was changed now it needs to be recoded. how do i do this?
2001 optima alarm keeps going off car won't start after new car battery replacement
haul it to a dealer and have it recoded . you have one that should have had a battery hooked to it when changing the battery . you have no other option
Jul 30, 2015 | Cars & Trucks
I need to change my battery on a Ford Galaxy 2007 2L TDCI, I know my radio code. I've been told it may affect the alarm/immobiliser system and I may need my keys recoding by the dealer, is this true? Any...
IT is possible that the battery removal will affect the CPU program which controls the immobiliser as some times the power surge on reconnection causes this. Useing a scanner to reset the CPU program should fix the problems
Apr 02, 2014 | 2007 Ford Focus (3 Door) Hatchback
I have a 2003 mirage I'm trying to recode it for a new remote the alarm is factory now nothing is flashing now I disconected the battery for 30 seconds still nothing?
disconnecting the battery some times corrupts the CPU program and seldom achieves much . Use a code reader to reset the CPU and the alarm
Mar 03, 2014 | Cars & Trucks
My security light came on and will not let me start my car. How do you bypass it to start the car?
you CANNOT bypass the anti theft device(whats the point of fitting it if you could)buy new remotes/change batteries in old remotes/get keys recoded/reset alarm system.in other words NO keys NO car.
Jun 26, 2010 | Cars & Trucks
First: alarm went off on its own.(mazda 6 2003). Now when locking and unlocking car sometimes indicators flash and sometimes not. Now red immobaliser light is flashing on dash when driving, then stops...
there is often a small back up battery in the immobiliser unit itself, if you can locate this unit and replace the battery with the ignition on / engine running, then it should not need recoding and work fine after that. The other thing that could be wrong is the key battery (if the fob has one) or the transponder chip in the key head. If the key signal is low the immobiliser lamp will light during driving, but this does not explain the alarm going off. That is more likely either a poor vehicle battery, alarm / immobiliser back up battery, or another electrical fault such as water leakage into a tail-light or even the alarm unit itself when it rains. A lot of alarms are voltage sensing and when the vehicle is parked they will alarm if the battery voltage changes for any reason, though not during driving so the battery in the immob is my first choice to look at.
Oct 24, 2009 | 2003 Mazda Mazda6
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
Disconnecting the factory alarm on a 99 vw beetle
well know you need to take the keys to the dealer ship and have the keys recoded becuse when u disconeded the alarm the code was read by the alarm know you have to recode it hope this helps .if you have a dummy key try it and see if the same thing happens when you turn it on if it does then have keys recoded. hope this helps
Mar 17, 2009 | Volkswagen Beetle Cars & Trucks
1994 BMW 7 series radio issues
need to have car battery ckeck for voltage drop...if ok...put ingition key in run position for twenty four hours and recode radio..
Oct 11, 2008 | 1997 BMW 7 Series
Dei 504d  Double Guard Shock Sensor Alarm Logo
242 people viewed this question
Top Stinger Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Stinger Vehicle Part and Accessory Expert? Answer questions, earn points and help others
