Question about Epson Stylus Photo R300 InkJet Printer
Won't turn on
Had a power outage; now the printer won't turn on. what is wrong and what can I do to correct the problem.
  • Anonymous Jun 03, 2008
    I have the same problem with my R300. It just quit working. The display does not show a thing, it is as if there is no power going to it.
    This also started in early May, 2008.
  • Cab0 May 11, 2010
    Hi
    I seem to be having the same problem with my R300 did you get a solution yet.
    Regards Carole
No solution. Even the company tech support could only suggest to take it to a repair shop to have it checked out; and the cost just to have them look at it before the cost of repair is prohibitive. A really lousy product, not to mention a lousy company, if this is all they can suggest.
Posted on Jun 06, 2008
    Problem Solver:
  • 14 Answers
Did you try plugging the unit into another power outlet?
Posted on Jun 04, 2008
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Will not turn on. after a power outage.
HI. this will happen during most outages. there is a fuse located inside the power supply device that is used to power your unit. simply remove the cover off the power supply box, and replace the fuse inside. this will correct the issue.
***((Now, if the fuse is OK, and not harmed, this will confirm that the power supply has failed. It should be replaced in this case))
Sep 09, 2009 | Nintendo Wii Console
Alarm on continuously!
please try to reinstall the printer drivers
Feb 13, 2009 | Citizen IDP3541 Matrix Printer
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Epson Stylus Photo R300 InkJet Printer Logo
157 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
