I need a wiring schematic for a Goodman mini split model wmh12-1a I'm converting this air handler to electro mechanical
BearWeb
  • 357 Answers
SOURCE: need wiring schematics for goodman
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
Posted on Jun 27, 2008
kstfas
  • 75 Answers
SOURCE: goodman split unit that heats instead of cools
Hi, Could be a run capacitor on the fan motor. They usually swell up and or leak when they go bad. If not, the only real way to test them it with a specific capacitor tester. A new capacitor would be cheaper. Make sure that the outside unit is disconnected from power before opening it up, try to spin the fan blade by hand. If it doesn't spin freely it may need oiled if possible. See above solution. Your problem is the fan motor though so if this don't do it, It will have to be replaced. If this helps, Please rate my solution. Thanks, kstfas
Posted on Aug 31, 2007
  • 121 Answers
SOURCE: Wiring diagam for goodman heatpump
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
  • 306 Answers
SOURCE: Air handler motor and capacitor
Just take out the fan and capacitor they are not OEM so any fan motor would work as long as same Horsepower and milti speed. And the capacitor is a 5 uf or maybe 7.5. You might have to cut off the shaft of the new fan motor so it don't stick out.. You can get a new fan and capacitor at any Heating and Air parts house. And you are sure they are bad you ohmed them out? Fans are not cheap about 50-75 bucks retail. Let me know how it goes. ken
Posted on Dec 23, 2008
jumptrout51
  • 3361 Answers
SOURCE: Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Posted on Apr 28, 2009
My air handler runs with the state in off position. I can turn it off by the breaker. Goodman GSZ130361AB only 6 years old had regular service since installed.
You are probably experiencing a stuck fan relay. The fan relay could be on a control circuit board or it could be a standard old electro-mechanical relay.
Mar 29, 2015 | Goodman Heating & Cooling
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
Modle No. pa10ja042oooacaa I need a wiring schematic for this unit . this is a split system the thermostat wires and the sequence and the relay need rewiring.
this is a 10 seer straight cool unit only 2 wires going to the unit install a new contactor and the thermostat wires go to the contactor unless u are talking about the air handler this is not the model # for the inside unit
Aug 30, 2010 | Heating & Cooling
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
All the wires on the outside of my goodman airhandler
The wires on a Goodman Air Handler Red to R, blue or brown to c, yellow to y cool, green fan g, white to w heat
Dec 14, 2009 | Refrigerators
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
Jul 03, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
