Question about Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504
Water runs on, tank does not fill does not flush
  • 43,501 Answers
Call the 800 number on the top of the tank... they are experts at walking you through the checkout procedure and also sending you free replacement parts if you need them...
heatman101
Posted on Sep 02, 2010
Our WaterRidge toilet tank will not fill with water
This sounds like the float is getting stuck , while the toilet is trying to fill if you see the float ball that is attached to a arm that pivots , if you lift the float up it should turn the water flow off from trying to fill the tank , some problems that can stop this are the rubber seal that lifts up when you press the flush button to allow water to flush the bowl does not seal back in a position so that the tank can never fill , sometimes the float ball can get stuck which stops it from rising up with the water level and shutting off the water , but my best guess is that the rubber seal has started to perish or distort and needs to be replaced you can find this right at the bottom of the tank and it is directly connected to the flush button ,so if you inspect inside the water tank and press the flush button you will see that it opens up and lets water pour into the toilet bowl but if a tight seal can not be made water will never fill the tank
Sep 26, 2017 | Washing Machines
Trans fluid ed in coolant bottle did flush and two week brown oily goo in bottle
Flush coolant system again. Do you have a brown sludge in the oil. Do this get Preston coolant flush, drain radiator drain coolant tank, fill radiator with water, add the Preston run vehicle for about 15 min remove lower radiator hose from radiator. This will allow all residue to be removed from engine. Replace radiator hose. Fill radiator with appropriate amount of coolant. Disconnect tank from system and let water run through tank until it is clear. Reconnect tank and you should be good. Unless you have oil and coolant mixed which means a blown head gasket or cracked block
Jun 14, 2017 | Cars & Trucks
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
Is there a way to adjust the amount of water in your toilet bowl in order to improve the flush?
There is only one way to do this and that is to increase the water level in the tank. To explain the flush valve in the tank fills both the tank and refills the bowl at the same time if the valve runs longer to fill the tank it will at the same time put more water into the bowl. Now having said that the bowl will only hold a set amount of water before it starts running out into the drain. If the tank water level is at the line marked in the tank it will most likely not do much good to raise the level beyond that point and if the toilet you have is a 1.6 gallon flush tank I am sorry but learn to live with it.
Feb 11, 2011 | Plumbing
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Tank will not fill up after flush. i hear water
Fill valve in tank has a washer in it you take it off and make sure there is no trash restrcting flow and also chack out flaper to see if it is sealing correctly.
May 03, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Our Toto bowl does not fill up enough after flushing unless the lever is held down. What do I do to fix it? We have well water and a bit of mineral does build up on the fill tube.
The only adjustment available is to control how full the tank will be for the next flush. The water that runs down into the bowl after flushing comes through the same valve that fills the tank, so the problem (and solution) is entirely with the amount of water that runs into the bowl while the tank is filling. The tank is filling sooner than enough replacement water can run into the bowl. Make sure that the tube (usually a 1/2 inch rubber tube) that runs from the float valve to the pipe that fills the bowl (usually a 1 inch pipe with an open top) is actually delivering all of it's flow down that pipe. If the flow of water being delivered by that tube is slow, you will have to find and eliminate the restriction. You might be able to pull of the rubbber tube off of the float valve and stick a small drill bit (just using your fingers, not a drill) into the fitting where you pulled off the tube.
Mar 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
After flushing, water fills up tank and continues
Your problem is the water fill valve. Check this link.http://www.rd.com/17646/article17646.html
it's not the flapper or flush valve.
Mar 05, 2010 | Home
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. Any suggestions?
It's either plugged or the tank isn't filling properly.
If it's the tank then the fill valve in the tank needs to be adjusted. There should be a screw to adjust the float ball. Back the screw out until the fill valve starts to run;let the water run until the tank fills to the fill line then turn the screw back in.Try flushing the toilet. If that doesn't work then the toilet is probably plugged.
If it's plugged you may need to rent/borrow a snake to clear the line.
Oct 09, 2009 | American Standard 2071.016 Heritage One...
Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504 Logo
165 people viewed this question
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
