Question about HP Photosmart C5180 All-In-One InkJet Printer
Cartridge error Hi!, Had to change low yellow cartridge and when i put new cartridge the screen showed error for yellow cartridge. Had store replace cartridge with another new one but still same problem. Help!!!!!! Thanks, Shely
Shut down printer. Then remove all cartridges. Install each one at a time allowing printer to detect "Genuine hp cartridge installed".
do this for every cartridge. also check and clean contacts on the yellow print head.
Posted on May 11, 2008
  • 3 Answers
Remove the cartridge & install the new one cartridge other wise
My CLX-2160 keeps warning that the yellow toner is low. I have put in a new one, but it still gives the same error message. What could be the cause of this ?
is the toner a refilled toner cartridge..if it is try to change the chip around and make sure that the chip seet properly in the grooves.if it is a new cartridge go bak and exchange it.
Oct 19, 2010 | Samsung CLX-2160N All-In-One Printer
I just installed new cartridges (3rd set) and printer still says ink is low. How can that be? Is there something I can do to reset the printer color and black buttons. They show yellow instead of green....
Hi
If you replaced the cartridges with genuine Canon cartridges then there's probably a build up of ink under the cartridge carriage. Pull out all the cartridges and lift up the carriage. Clean it using a non alcohol cleaner. While you're at it put some cleaner on a folded up paper towel and wipe the ink reservoir located on the right hand side, where the carriage sits when idle. If you replaced your Canon cartridges with off brand cartridges then you might not have changed the chips over. On the old cartridges there's a tiny chip glued to the plastic in front. This chip must be popped off and snapped onto the new cartridge. Good luck
Apr 06, 2010 | Canon PIXMA MP210 InkJet Printer
The yellow spot is blinking and the black dot is
the solid light means toner is low. Blinking usually means either the cartridge is out of toner or the cartridge is having a technical problem. If you pull the yellow toner cartridge and put it back in with no change in result, you will need to replace the yellow toner cartidge
Nov 19, 2009 | HP LaserJet 1500L Printer
Will not print,shows65% on screen then printer shows cartridge error 50C see user guide book which I cannot find. My printer is registered with you.
this problem is most likely a damged, defective, or offbrand cartridge. that is what the error code 50C stands for. to test my theory, get an original lexmark black and color cartridge. don't buy it unless you have to. borrow it from a friend or from work. then, clean the inside of the printer with a vaccum and (using isopropal alchol). after performing these tasks, put the new cartridge in one at a time. Make sure you have one old and one new. for example, a new black and an old color. this will tell you which cartridge is defective and needs to be replaced. then fin yorself another company that sells the cartridges and try them.
Jul 09, 2009 | Lexmark X5150 All-In-One InkJet Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
Photosmart D7160 shows yellow empty even with NEW cartridge
Printhead problems are more common than perceived. Have you disconnected the power cord for the printer to flush the built-in board? Disconnect the printer USB cord as well. If this doesn't resolve the problem call for an RMA. Printheads are not inexpensive.
Jan 20, 2009 | HP Photosmart D7160 InkJet Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
REPLACING CARTRIDGE
You should be able to replace just the needed color.  Select menu, arrow right until "Engine" is displayed, select, select "Replace Toner" select color cartridge desired. follow directions on screen.
Jul 29, 2008 | Minolta magicolor 2350 Laser Printer
Overiding Empty Cartridge error for Dell A10 962
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
185 people viewed this question
Ben Johnson
