Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washer Model GWL11
We have water leaking from the bottom of our 2-1/2 year Washing Machine. Can you please tell us what the problem is as soon as possible ?
  • clebinla May 11, 2008
    Hi !!
    Thanks for the prompt response, but our water comes out of the "front" of the GWL11, not the back ?? Is this the same problem as yours ? Maybe the water is coming from the back of the unit to the front ? We've called the place where we purchased it, I guess they will come tomorrow (Monday). Please respond.
    Thanks
Clebinla,
I have the same problem with our GWL11. It just started yesterday. I think I found out where the problem is occuring. I noticed that there seems to be a crack in the small rubber tube that supplies the fill water. The water leaks out of this crack and runs down the back of the machine. I fixed the problem temporarily by putting a piece of plastic below the cracked tube that funnels the water into the tub. I am trying to locate a replacement for the tube but I haven't had much luck yet (it is a curved yellow tube that is a couple of inches long.)
Posted on May 11, 2008
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Water leaking from bottom of machine however I cannot find a leak when inspecting from the bottom with the machine tilted back. Fisher & Paykel model GWL11. I have not been able to determine when (...
Hi just read your posting.Now have you checked for the leak where the drain hose comes out of the case of the machine? It is located at the back top left of the machine.Have you checked the inlet hoses at the tap end and the machine end?Rub the inlet hoses with your hand from the tap to the machine on both hoses to feel if there is any water on them.Check the nozzle under the lid where the water comes into the machine to see if it is not loose or broken.Please reply and let me know how you got on and If you need further help.Looking forward to your reply.
Sep 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water is leaking from t he bottom of the washer
Hi just read your posting.Now in which part of the cycle is your machine leaking ?Is it when it is filling,or washing ,or draining ,or spinning?Have you managed to see where the leak is located?Please reply with additional information and I can help you further
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking on my fisher paykel washer. does it
Hi, It is due to a split in the flexible hose from the bowl to the pump. When machine is working, the split opens and closes, but when not operating it can be closed up enough to prevent seeing it leaking. .
Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
I've got a Fisher and Paykel MW051-U washing machine. Everything seems to work fine, but after each wash cycle i notice that it is leaking water, i've tilted it and confirmed that the water is coming from...
access through the back panel to have a look at the drain pump which is likely your fault. Run a cycle and watch it when it drains you will likely see water leaking from the pump (about $25 and easy to change)
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Washer. Leaking from bottom. Doesn't appear to leak during wash cycle.
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Jun 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
337 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
