Question about Innova Equus 3420 Smart Test Light/Circuit Tester
Equus 4320 fuze size - Innova Equus 3420 Smart Test Light/Circuit Tester
Equus #4320 multimeter
well this could be a few things wrong , first does this one have the built in rechargeable batterys ? if so there bad and need replaced , reason numbers counting down slowly . second does rotary selector look damaged or feel "loose" seems you have a bit of a bad connection in the rotary switch on front (could have gotten liquid down inside it too) yooul have to remove back cover (carefully !!) and wash out switch with contact cleaner (care to display window !!)
Aug 13, 2016 | Equus 4320 Digital Multimeter Ul Cul10...
Doesnt connect to pc
with Innova Equus 3130 live data software loaded to the pc
it needs the correct input cable
should work..... just push the right buttons on the scanner
https://www.youtube.com/watch?v=bEkQvg55ZYs
May 19, 2016 | Innova Equus 3130 Diagnostic Code Scanner
Paint coming off side passeninger door
This is usually caused by chips in paint or salt damage if the vehicle wasnt in a accident or could have been factory flaw if it was never repainted
Dec 13, 2012 | Equus Scan Tool for 02 2002 Saturn SL1...
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
2011 equss sunroof inop all fuses are good ????
2011 Equus is still under warranty. Take it to the nearest Hyundai Service Department & have it diagnosed & repaired under warranty.
Aug 31, 2011 | 2011 Hyundai Equus
I need to know how to wire up my equus model#6076 tackometer
The instructions should have come in the box with the tack
if not an auto supply shop can tell you but you will need to know the make and model of it.
Jim Hart
Jun 20, 2010 | Equus 6086 Black Tachometer Measures 2 12...
Printer reprinting the allready printed pages
Make sure that your document that u r printing's page size is set to A4!Good luck!
Apr 05, 2010 | Canon Office Equipment & Supplies
ACER Aspire 4320 Laptop LCD Inverter 14.1
Your best bet would be ebay. We can source one for you but it would be cheaper on ebay.
Nov 22, 2009 | Acer TravelMate 4320 Notebook
Innova Equus 3420 Smart Test Light/Circuit Tester Logo
376 people viewed this question
Top Innova Measuring Tools & Sensors Experts
ray gallant
Vuk B
Tom Chichester
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
