Question about Car Audio & Video
How many miles can a 99 v6 camry solara can go before chaning oil
  • 132 Answers
Usually recommend every 3000 miles. If over 100,000 miles on vehicle then I typically upgrade to a high mileage oil
Please leave positive rating as well.
Posted on Sep 03, 2010
2000 Toyota solara v6 180822 miles car starts with low idle and seems like its not getting enough fuel. Where is the shredder valve located please help thanks
there is no shredder valve.
ever get a tune up this decade? if not , now be that moment?
does CEL lamp glow keyon
and stay out running
no matter, get it scanned, see if there DTC errors ???
that be first. checks.
Jan 29, 2015 | 2000 Toyota Camry Solara
Body damage back right wheel 2000 solara
your lucky ,if they offer that amount take it ,was the car insured ??? know what i mean ------ sorry your car was stolen
Apr 01, 2010 | 2000 Toyota Camry Solara
How to change oil on a v6 solara 2002. Where is the filter located? How big is the socket for the drain plug and how many quarts of oil does the car require?
since there are so many variations of the particular car you own, i recommend you go to the local auto parts store pick up a manual and follow the instructions there...it will have a detailed step by step on how to do it...
Nov 13, 2009 | 1999 Toyota Camry Solara
2002 toyota engine, oil sludgecaused my car to stopped and now needs overhaul
Complain to Toyota, they are fixing some of these car for free. Here is the explanation and the list of problem vehicles.
Oil sludge or black sludge is a solid or gel in motor oil caused by the oil gelling or solidifying, usually at temperatures lower than 100 degrees Celsius. Sludge can be a major contributor to Internal combustion engine problems, and can require the engine to be replaced, if the damage is severe. Sludge is usually caused by the presence of water in the oil, and can accumulate with use. Ways to minimize sludge production and accumulation includes performing frequent oil changes, using synthetic oil, and following the manufacturer's engine maintenance routine.
The following engines were reported by the Center for Auto Safety and/or their manufacturers to have a problem with sludge accumulation:
  • 1996-2001 Toyota 3.0 L 1MZ V6
  • 1996-2001 Toyota 5SFE I4
  • Feb 23, 2009 | 1995 Toyota Camry
    Does a 2005 Toyota Solara se V6 Require timming belt change
    EVERY 90,000 MILES OR 72 MONTHS ON A 3.3 ENGINE
    2.4 DIESEL 100,000 MILES
    Feb 11, 2009 | 2005 Toyota Camry Solara
    Location of oil filter on 2007 Toyota Solara Convertible
    The 3.3 no longer has a "spin-on" filter. The filter is now a "cartridge-type", and is housed in a cricular aluminum housing under the engine.
    Jan 02, 2009 | 2007 Toyota Camry Solara
    Belt or chain on 2005 solara
    The 3.3 litre Solara V6 has a timing belt.
    This belt is recommended to be replaced every 90,000 miles.
    Please feel free to comment back if you have any other questions.
    Hope this helps, and Thanks for Choosing FixYa.
    Dec 01, 2008 | 2005 Toyota Camry Solara
    1999 camry
    I came across a couple of toyota service bulletins addressing these issues (as I am also suffering from rough idling and persistent check engine light(that sometimes blinks)):
    Title:
    DIAGNOSTIC TROUBLE CODE P1133
    Models:
    ’97 – ’99 Camry: 1MZ–FE CA Spec.
    Technical Service
    BULLETIN
    February 25, 2000
    TSB Revision Notice:
    The information updated in this TSB is red and underlined.
    Under certain driving conditions, some 1MZ–FE equipped 1997 – 1999 Camry California
    Emission specification vehicles can exhibit a M.I.L. “ON” DTC P1133. An improved
    Air/Fuel Ratio Sensor has been developed to correct this condition.
    1997 – 1999 Camry (1MZ–FE) with California Emission Specification.
    MODEL YEAR ENGINE STARTING VIN
    1999 Camry 1MZ–FE
    4T1BF2#K * XU088001
    4T1BF2#K * XU933227
    PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME
    89467–41020 89467–41021 Sensor, Air/Fuel
    Should a M.I.L. “ON” condition with DTC P1133 be encountered, perform diagnostic
    procedures as described in the Repair Manual.
    If the problem source cannot be identified after checking all affected areas according
    to the Repair Manual, the cause may be an Air/Fuel Ratio Sensor malfunction. In this
    case, replace the Air/Fuel Ratio Sensor with the current part number listed above.
    If the Exhaust Manifold threads are damaged by removal of the sensor, they can be
    repaired by the proper use of a M18 x 1.5 tap.
    OP CODE DESCRIPTION TIME OPN T1 T2
    895131 R & R Air/Fuel Ratio Sensor 0.3 89467–41020 99 99
    Applicable Warranty*:
    This repair is covered under the Toyota Basic Warranty. This warranty is in effect for
    36 months or 36,000 miles, whichever occurs first, from the vehicle’s in–service date.
    Coverage is extended to 36 months or 50,000 miles, whichever occurs first, in the
    states of California and Massachusetts due to state emissions warranty legislation.
    NOTE:
    Please enter the DTC in the condition/Cause/Remedy section when applying for
    warranty reimbursement.
    * Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
    Title:
    SINGLE CYLINDER MISFIRES
    Models:
    ’99 Avalon, Camry, Sienna & Solara (CA Spec.)
    Technical Service
    BULLETIN
    January 14, 2000
    NOTE:
    The information contained in this TSB updates EG013–99 dated December 17, 1999.
    Some 1999 California Emission Specification Avalon, Camry (1MZ–FE), Sienna & Solara
    (1MZ–FE) vehicles may exhibit a rough idle, and or a M.I.L. “ON“ condition, in which a
    single cylinder misfire code, or codes are present. Changes have been made in the fuel
    injector production process to correct this condition.
    1999 CA Emission Spec. TMMK produced Avalon, Camry (1MZ–FE), Sienna &
    TMMC produced Solara (1MZ–FE) vehicles built between the VIN numbers listed
    below.
    MODEL STARTING VIN ENDING VIN
    Avalon 4T1BF1#B*XU298504 4T1BF1#B*XU319557
    Camry 4T1BF2#K*XU076403 4T1BF2#K*XU081214
    Camry (cont.) 4T1BF2#K*XU930024 4T1BF2#K*XU931330
    Sienna 4T3ZF1#C*XU090887 4T3ZF1#C*XU122589
    Solara (U.S.) 2T1CF2#P*XC111083 2T1CF2#P*XC757508
    Solara (Canada) 2T1CF2#P*XC744113 2T1CF2#P*XC162681
    APPLICABLE PARTS QUANTITY PART NAME
    23209–0A010 6 Fuel Injector
    OP CODE VWC DESCRIPTION TIME OPN T1 T2
    895221 N R & R Fuel Injector Assembly – All 1.8 23209–0A010 02 56
    This repair is covered under the Toyota Federal Warranty. This warranty is in effect for
    states of California, Massachusetts, and Vermont due to state emission warranty
    legislation.
    NOTE:
    Be sure to enter the DTC No. in the Condition/Cause/Remedy section, if a DTC Code
    appeared.
    ENGINE
    Introduction
    Applicable
    Vehicles
    Parts
    Information
    Warranty
    Information
    SINGLE CYLINDER MISFIRE – EG001-00 January 14, 2000
    Page 2 of 2
    1. Remove all six fuel injectors for
    verification of production information.
    Affected injectors will be labeled with
    a vendor part number of
    “23250–0A010“ and have a
    production date code number of “828“
    or lower (see illustration for number
    locations).
    2. After determining that one or more of
    the injectors are affected, replace all
    six injectors with the above applicable
    part number.
    3. Clear the DTC, if present, and verify
    that the vehicle now operates as
    designed.
    Jul 03, 2008 | 1999 Toyota Camry
    Car Audio & Video Logo
    24 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
