Question about Fossil Starck Modern Digital Watch - O-ring Digi - White/Orange PH1094
How do you remove the buckle pin from a Fossil Starck O-Ring Watch?
  • Jewel
    Jewel Sep 03, 2010
    Thanks for contacting FixYa. I am not too familiar with this watch but looking at a picture, it looks like you should be able t stick a pin in where the watch pin is. Are you trying to shorten the band? Jewel
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
Posted on Aug 09, 2008
  • 4 Answers
SOURCE: philippe starck with fossil ph-2006
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
escapement
  • 2334 Answers
SOURCE: Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Posted on Dec 17, 2008
escapement
  • 2334 Answers
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Posted on Dec 19, 2008
SOURCE: fossil watch band adjustment
throw the ******* thing away
Posted on Dec 25, 2008
How many batteries for starck o ring
Take your watch to a jeweler for an accurate battery count and perhaps replacement.
Aug 26, 2014 | Fossil Starck Modern Digital Watch -...
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
REQUIRE REPLACEMENT GLASS FOR FOSSIL STARCK O RING PH 1085 901008 WATCH.
same problem. If this is a design defect I would hope they would replace it free
May 29, 2011 | Fossil Watch PH1085
Hi there I'm desperately looking for a replacement black rubber strap for my Fossil/Starck O Ring watch. Please let me know if you have any advice for me. thx Greg
Go to their web site "fossil.com" and at the bottom of the page there is a menu.
Click on "customer care" and you will see another page with a menu on the left.
Click on "order links and bands" and follow instructions.
May 24, 2011 | Fossil Watch PH1085
Cant set watch
Follow this link: http://www.fossil.com/webapp/wcs/stores/servlet/Static____Instructions_custCareNav Scroll down and find Philippe Stark watches, then click on appropriate watch. Rate me, plz.
Jan 27, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
Starck watch PH 1071 110504. I just need to chance the time but I can't.
try this link to get help;
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
Rate, please.
Jul 28, 2009 | Fossil Starck Modern Digital Watch -...
Dec 19, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
May 15, 2008 | Fossil PH1057 Wrist Watch
Fossil Starck Modern Digital Watch - O-ring Digi - White/Orange PH1094 Logo
202 people viewed this question
Top Fossil Watches Experts
Jimmy Accardi
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
