Your answer was very good thank you. I have my Dell monitor apart but cannot find the capacitors.....Below is the model and part number from Dell 9E249 Display, Flat Panel, 20, DUAL..., 2000FPMidnight Gray, DELL AMERICAS ORGANIZATION Each of the parts marked C101, C102 etc or similar, is a capacitor. On the side of the capacitor are some values EG: 1000uF/16V or 470uF 25v or 2200uF 10v Thanks for your help Tim Glavin
    Genius:
  • 1,478 Answers
The problem posted is not clear enough, i need more information on the problem posted. If you are looking for a place to get capacitor, you can check ebay.com or ereplacementparts.com
Take care.
Posted on Sep 02, 2010
Monitor is blank. it stays on for 2 seconds when I turn the power off and on.
You have one or more blown capacitors inside your monitor. You need to carefully take it apart, find the bad capacitors, remove them and solder in new ones. They are not difficult to find, as they are supposed to be flat on top, but the blown one(s) will be round on top. If you go to Youtube, you can find some excellent videos on how to take apart your monitor and replace the blown capacitors. It is not difficult, nor expensive, and once you do it, your monitor will be as good as new.
Feb 22, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Tip
Dell Monitor Repair
How to fix a Dell Monitor that just flashes the power light or also flashes the screen on and off very fast. In this video I repair my E178FPb with this problem. In my video, I show how to take it apart, recognize the problem, and replace the parts. I ordered the parts off Mouser and it only cost around $6 with shipping. The problem was visual and I found 2 electrolytic capacitors bulging and a ceramic capacitor burnt. Mouser Electronics Electronic Components Distributor
on Jun 10, 2015 | Dell E178FP 17 inch LCD Monitor
The screen flashes on my Dell 1905FP Monitor, Is there a fix?
This is a common indication of bad filter capacitors on the power supply board. Below is a picture of the power supply board with the problem capacitors circled in yellow. The repair is easy, you just need to replace those capacitors and the unit should be as good as new. Below the picture is also a link to a full repair guide showing how to dis-assemble the monitor and what parts need to be replaced. the repair guide has a full parts list for the job.
The repair guide can be found here:http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 26, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
My dell monitor 1703fps comes on for about 2 seconds
i think if you can service your monitor please see all the filter capacitor i think capacitors leak and need for replacement.
Sep 28, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
How do I connect my apple model m7649 monitor to a dell laptop? Thanks to anyone, ron
you should be able to get hold of a convert that plugs in to your laptop then you should be able to plug the monitor in to the converter with out having any problems with display settings
hope the information is abit of help to you
Mar 04, 2009 | IBM (14R0060) Monitor
My Dell Monitor on/off switch blinks green all of the time.
You need to open the monitor and check to se eif any of the capacitors on the power board are bad. Common problem for LCD monitors. The bad caps usually vent at the top (they will look bad compaired to a good capacitor).
If they look bad then they will need to be replaced. I've seen this in Dell monitors, so there's a good chance this will fix the monitor.
Take it apart, get the values on the sides of the bad caps in the power supply pcb. Buy new caps, and de-solder the old ones and replace them with the new ones. Don't forget to trim the leads afterwords.
Jan 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 1907FPT lcd monitor
Could be the power supply. Get one at www.partstore.com. I've had very good luck with them fixing various LCD monitors.
Jan 08, 2008 | Dell E173FP 17" LCD Monitor
Dell LCD monitor flashes white every second, and then goes black
buy a new one PLEASE, HD monitor works best but the least expensive ones are smaller
Mar 25, 2007 | Dell E173FP 17" LCD Monitor
E153FP Monitor screen goes black light is green
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Oct 23, 2006 | Dell E153FP 15" LCD Monitor
Power button doesn't work...
Your problem is not the switch. Probably you have faulty capacitors, deteriorated solder joints or worn out bulbs.
To open the case, remove the base (push button and lift off).
remove any screws under the base plate.
Pry the front and back cover apart, they snap together.
Good luck,
Monitor Mike
Oct 12, 2006 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
