I recently moved in to a older mobile home and my washer shakes like you can't beleive on the spin cycle. It was find in my other home before I moved, any suggestions? I put a level on it and it is level side to side and front to back.
    Genius:
  • 1,028 Answers
Weak flooring is number 1 possiblility might try thick plywood cut to size and screwed to floor not just laid down
Posted on May 11, 2008
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer shakes bad during spin
Could also be the drum bearing has collapsed or about to
Apr 28, 2017 | Kenmore Washing Machines
Washer was making a very loud shaking sound in the spin cycle, the noise stopped the spinning stopped and I smelled burning.washer will not spin
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 27, 2010 | Frigidaire Washing Machines
Maytag lat6914aae top load washer shakes violently in spin cycle
A washer can have self leveling legs at the back. If they are rusty or clogged and not free to move, they will not self level and the machine will rock when working. Check the leveling apparatus, it's a bunch of metal pieces going across the lower back of the machine. Spray them with a lubricant and move them to make sure they are free.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
While replacing motor coupling and vigorously moving motor gearbox around, something dropping on the base of drum but could not see what it was. And after completing the motor coupling job , I set the...
those pins are not important they are there for transportation purposes such as moving from one home to another or country don't worry about them. As far as the shaking and walking use a level and level your machine in both directions.
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
Apr 03, 2008 | Kenmore 22422 Top Load Washer
Our washer shakes badly at the spin cycle
look on the back and take the shipping pins out there are 4 bolts on the back of the machine the only only ones that are 1/2" socket size or 7/16" pending on the machine.
Jan 04, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
